Dump Submitted - Arcane Season 2 4K (Collector's Edition 4K)
CoffeeDrinker
Post by CoffeeDrinker » Thu Dec 18, 2025 5:57 pm
I'm not sure if these are exactly the same discs as the 4K Steelbook.
This is what popped up on my log:
"Loaded content hash table, will verify integrity of M2TS files.
Saved AACS dump file as /Users/user/Library/MakeMKV/MKB20_v82_ARCANE_SEASON_2_-_DISC_1_FFC6.tgz
Failed to open disc"
Last edited by CoffeeDrinker on Thu Dec 18, 2025 11:00 pm, edited 3 times in total.
CoffeeDrinker
Re: Arcane Season 2 4K Disc One Not Reading
Post by CoffeeDrinker » Thu Dec 18, 2025 6:12 pm
I've never had to submit a dump before, but I will send an email out about it.
CoffeeDrinker
Post by CoffeeDrinker » Thu Dec 18, 2025 10:55 pm
Dump submitted for all three discs, and sent it to the email. I'm sorry I'm not tech savvy and I'm not entirely sure how all of this works.
I was supposed to submit the .tgz files unzipped, right?
Re: Dump Submitted - Arcane Season 2 4K (Collector's Edition 4K)
Post by dcoke22 » Fri Dec 19, 2025 7:26 am
Just attach a .tgz file to an email and send it. .tgz files are usually compressed tar files. Since they're already compressed trying to compress it again with zip won't really help. :)
CoffeeDrinker
Post by CoffeeDrinker » Fri Dec 19, 2025 5:09 pm
Well, I sent out the email yesterday. I hope they get it. At first uncompressed it, and found the file in the folder called 'dump.' So I sent that, then I realized that since it's a tv season boxed set, I should do the same for the other discs. Then I thought I didn't send the file properly. So the email thread for me had like 5 messages. :( (yes, I did eventually send the .tgz files)
So hopefully they'll get it. Just to be clear, how long do people typically wait after submitting a dump, and how do these updates work? I'm so sorry, I don't quite know how this process works.
Post by dcoke22 » Fri Dec 19, 2025 6:21 pm
You won't get a response via email. Historically, it is has generally only been 2 or 3 days for a hashed key to be created. With AACS v82 on regular blu-rays, the volume of keys needing to be generated has gone up and the time for keys to be created has grown longer.
Assuming your installation is configured to access the internet (it is by default, but can be turned off in preferences) and assuming you can access the necessary server (located in Russia currently) MakeMKV will download the latest keys when it encounters a disc it doesn't have keys for. Just try your disc(s) again in a few days. You should see a message in the long about downloading the latest HKs when it does so. Or, a message that the download failed, which is a different problem to solve. If there's no message, then there were no new keys to download (they get published in batches).
In the meantime, you could download and configure the public keyDB. It is an alternative source of decryption keys that MakeMKV also supports. Dumps from Pioneer drives aren't that useful to them to add keys, but any brand of drive can make use of existing keys from the keyDB. The first post in the Public KeyDB Disc Submission thread has more details. (The short, short version is download and unzip the keyDB.cfg file and put in the same directory MakeMKV it putting the .tgz dump files - this is MakeMKV Data Directory as configured in preferences. Restart MakeMKV and try your disc.)
MakeMKV can use both sources of keys, the built-in hashed keys and the keyDB. The keyDB is often updated faster than MakeMKV's hashed keys, but it requires extra work on your part as it doesn't automatically update itself.
CoffeeDrinker
Post by CoffeeDrinker » Sat Dec 20, 2025 12:52 am
So my drive is a Pioneer, so I think I'll just have to wait then? I'll try to rip them in a few days, I suppose. Even though I used Pioneer, was it still useful for me to send out that email?
Post by dcoke22 » Sun Dec 21, 2025 3:29 pm
It was very useful for you to email your dumps from your Pioneer drive.
The public keyDB can't really make use of MakeMKV's dumps from your Pioneer drive to add new keys to the keyDB. (This is a more complicated topic actually but not worth going into here.) However, even with your Pioneer drive MakeMKV can use the keyDB as a source of keys to try to decrypt discs. So, emailing your dumps is very helpful, but you need not wait for those dumps to be turned into hashed keys. You should download the keyDB and set it up for MakeMKV to use. Maybe the keys you're in need of already exist in the keyDB.
