This movie and the original simpsons movie on bluray are the only 2 movies to never actually spin up in my external player for makemkv. Will literally sit dead in the player for several seconds before ejecting.
Plays just fine in my LG UBK90. My Pioneer is on 1.01. Is there anything I can do for this drive to get it to read this one single movie?
Anyone elses copy of TMNT 2 4K by Arrow not playing in their Pioneer BDR-XS07UHD?
InTheZoneAC
Re: Anyone elses copy of TMNT 2 4K by Arrow not playing in their Pioneer BDR-XS07UHD?
Have you tried gently cleaning the disc?
I have many issue with this disc. Three drive each have problem. Pioneer drive different model.
1. Disc not seen by drive.
2. Cleaning.
3. Many remove and clean and insert.
4. One time drive see disc.
MakeMKV fail error:
Xreveal crash
5. More remove and clean and insert
6. One more time drive see disc.
7. Xreveal rip. Is clean? Unknown. MakeMKV fail.
8. Remove insert 25 time. Drive never see disc again.
2. Cleaning.
MakeMKV fail error:
001012:0000 udf: node fe/efe failed!5. More remove and clean and insert
InTheZoneAC
I own the same player and I am having the same issue as you on a brand new and flawless disc.
I had a hell of a time getting this disc (TMNT 2 specifically) to rip. The other two movies in that set went quickly and flawlessly.
At first I couldn't even get the disc to initialize in my Billy-bought BDR212 (makemkv had been open before I put the disc in.) So I threw it in my UB820 and it played fine. While I was doing that, I restarted my computer, then I let the disc initialize in windows first, and then opened it in makemkv. It repeatedly threw a scsi error while initializing. I don't remember the specific error was but it had to do with *write* media being invalid (an error type I'd never seen before, and I have had a couple of generally unreadable discs in the past...) but eventually (after 2-3 minutes) it somehow ... got through? ... and then the disc ripped cleanly as if nothing had happened, at full speed for the drive (4.0x).
Couldn't tell you what happened, but it made me pucker a little bit.
mirrorworld
Yes. I have the same drive and TMNT 2 isn't reading either. Both 1 and 3 work fine.
Same issue. Disc try's to read for a bit then ejects. 1 and 3 worked with no issues. Going to try cleaning it really good today and see if I can get any progress.
TMNT 2 is ripping and playing fine but #1 1990 is crashing plex on Windows an AppleTV
https://www.reddit.com/r/PleX/comments/ ... rom_arrow/
Topspin14m
I cannot rip the second file (with surround sound rather than stereo) from TMNT 1. Keeps erroring out. Disk looks flawless so no idea what's wrong...
