Verbatim 43890 External Slimline Mobile USB 3.2 Blu-ray Writer UHD Problem
StarryEyed
Re: Verbatim 43890 External Slimline Mobile USB 3.2 Blu-ray Writer UHD Problem
Post by StarryEyed » Sun Dec 07, 2025 11:51 am
Coopervid wrote:
Fri Nov 28, 2025 1:54 pm
StarryEyed wrote:
Fri Nov 28, 2025 1:41 pm
My optical drive has recently failed so looking to get a replacement. Before purchasing can I ask a sanity check please: if I get a Verbatim 43890 will I be able to flash this drive myself?
If it's new stock it contains a LG BU40N and you can flash it according to the UHD guide. If it's old stock it might contain a Pioneer UD03 and you have to post again so I will forward a package to flash it.
Many thanks my drive has arrived and I have some spare time to flash it. The drive info is
OS device name: F:
Product: BD-RE BU40N
Revision: 1.05
Serial number: ...
Highest AACS version: 82
So all looks good to me as platform is MT1959. What is the recommended way to flash the above drive I understand I should flash to BU40N 1.03. Do I need the enc option and should I use the makemkv inbuilt flasher as I am ok with using the command line or use the GUI flasher?
I am also keen to get a second internal optical drive are there any internal drives still available that can be flashed?
Post by Coopervid » Sun Dec 07, 2025 11:56 am
OS device name: F:
Revision: 1.05
Serial number: ...
Since you are on Windows, just use SDFTool and the "All you need firmware pack" to flash 1.03.
viewtopic.php?f=16&t=22896&hilit=sdftool+flasher
Drive supply is critical. Also LG stopped now making optical drives. Let me know your country of residence and I will check for an internal drive.
StarryEyed
Post by StarryEyed » Sun Dec 07, 2025 1:15 pm
OS device name: F:
Revision: 1.05
Serial number: ...
Flash process worked great. Managed to get the Verbatim flashed drive to work - first time it failed to open the disc. Had to do a system reboot first for MakeMKV to be able to read the drive in Libre format.
I am UK based so having a second internal drive would be very handy, I was shocked when my drive failed I thought that was the end. Glad to get the Verbatim working but also keen to get a replacement internal optical drive if that is possible.
Post by Coopervid » Sun Dec 07, 2025 4:57 pm
PM sent.
json7
Post by json7 » Fri Dec 12, 2025 12:35 am
@Coopervid
I purchased the Verbatim 43890 with the following info from MakeMKV and would like to make it compatible with reading UHD discs. Any help would be greatly appreciated! Thanks!
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number:
Firmware date: 2020-06-15
Highest AACS version: 76
Drive platform: RS8511
Firmware version: 1.14
Post by Coopervid » Fri Dec 12, 2025 12:40 pm
@Coopervid
OS device name: E:
Revision: 1.14
Serial number:
PM sent.
TheFlasher
Post by TheFlasher » Sat Dec 13, 2025 3:36 am
@Coopervid
I have also purchased a Verbatim 43890 it does Blu rays perfectly but was wondering how do I get the PM for the flasher to make it UHD capable?
Revision: 1.14
Serial number: CIDL502547WL
Post by Coopervid » Sat Dec 13, 2025 8:51 pm
@Coopervid
Revision: 1.14
PM sent.
parkthebus
Post by parkthebus » Sun Dec 14, 2025 5:43 pm
Hi I found this thread searching for drive info. Here is the makemkv info below. Is this workable and can you send a PM if so?
OS device name: E:
Revision: 1.14
Serial number: ------------
saskBee
Post by saskBee » Sun Dec 14, 2025 7:18 pm
@Coopervid
I have also recently purchased the same drive. Is it possible to get the same flashing kit?
Revision: 1.14
Serial number:
Post by Coopervid » Mon Dec 15, 2025 9:52 am
OS device name: E:
Revision: 1.14
PM sent.
Post by Coopervid » Mon Dec 15, 2025 9:54 am
@Coopervid
Revision: 1.14
Serial number:
PM sent.
saskBee
Post by saskBee » Mon Dec 15, 2025 7:07 pm
@Coopervid
Revision: 1.14
Serial number:
PM sent.
Thank you, that worked perfectly!
zittrig
Post by zittrig » Wed Dec 17, 2025 5:36 pm
Little big problem with a 43890 with Pioneer BDR-UD03 ..... :x
Power outage while flashing process .... I was flashing the drive for a friend and I always testing by using all cables. Power cable connection included.
A few seconds after starting the flashing process power is gone. Notebook worked with accu and the Y-Power-Cable was connected also. But without electric power the flashing process was interrupted and the drive now is not usable. :cry:
Is it bricked? Or can I rescue it?
Post by Coopervid » Wed Dec 17, 2025 6:32 pm
Don't know. It should be most likely in kernel mode. Just run the Flasher and check. Report back.
