You need to post your Makemkv info.beflapje wrote: Wed Dec 17, 2025 9:31 am Hello ,
Can i flash this drive to support UHD-BR
Vendor Product Rev
PIONEER BD-RW BDR-UD03 1.11
Interconnect: USB
SupportLevel: Unsupported
Profile Path: None
Cache: 4000k
CD-Write: -R, -RW, BUFE, CDText, Test, IndexPts, ISRC
DVD-Write: -R, -R DL, -RAM, -RW, +R, +R DL, +RW, BUFE, Test
BD-Write: -R, -RE
Strategies: CD-TAO, CD-SAO, CD-Raw, DVD-DAO
Thank you
Pioneer BDR-UD03 UHD possibility
Re: Pioneer BDR-UD03 UHD possibility
PM sent.Higgie wrote: Wed Dec 17, 2025 11:44 am Hi, is my drive a candidate for reading UHD Discs? Thanks!
Drive Information Manufacturer: PIONEER Product: BD-RW BDR-UD03 Revision: 1.03 Serial number: Firmware date: 2015-05-14 Bus encryption flags: 1B Highest AACS version: 75 LibreDrive Information Status: Enabled Drive platform: RS8510 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.03/ID19 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
beflapje
Drive InformationCoopervid wrote: Wed Dec 17, 2025 3:50 pmYou need to post your Makemkv info.beflapje wrote: Wed Dec 17, 2025 9:31 am Hello ,
Vendor Product Rev
Interconnect: USB
Profile Path: None
Cache: 4000k
BD-Write: -R, -RE
Thank you
Revision: 1.11
Serial number: TGDL331832WL
Firmware date: 2018-11-28
Drive platform: RS8511
Firmware version: 1.11
PM sent.beflapje wrote: Thu Dec 18, 2025 6:51 amDrive InformationCoopervid wrote: Wed Dec 17, 2025 3:50 pmYou need to post your Makemkv info.beflapje wrote: Wed Dec 17, 2025 9:31 am Hello ,
Vendor Product Rev
Interconnect: USB
Profile Path: None
Cache: 4000k
BD-Write: -R, -RE
Thank you
Revision: 1.11
Nilplunk
Same as all the others
OS device name: /dev/rdisk7
Revision: 1.14
Serial number:
Firmware date: 2020-06-15
Firmware version: 1.14
Unrestricted read speed: Yes-
Pm sent.Nilplunk wrote: Thu Dec 18, 2025 6:08 pm Same as all the others![]()
Drive Information OS device name: /dev/rdisk7 Current profile: BD-ROM Manufacturer: PIONEER Product: BD-RW BDR-UD03 Revision: 1.14 Serial number: Firmware date: 2020-06-15 Bus encryption flags: 1B LibreDrive Information Status: Enabled Drive platform: RS8511 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.14 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
daughtersofdarkness
Hey @Coopervid
I got the same drive as the others. Any chance you can help me as well? Many thanks in advance!
Revision: 1.14
Serial number: AEDL396610WL
Highest AACS version: 82
Revision: 1.14
SCloop
I would appreciate assistance in enabling UHD disks on this drive. Thank you in advance.
OS device name: G:
Revision: 1.14
Serial number: DDDL527751WL
OS device name: G:
Revision: 1.14
Fredbj
Hello @Coopervid
Could you please help me as well?
Revision: 1.14
Serial number: BADL464264WL
Revision: 1.14
kobayashison
Same as the others! Thank you in advance!
Current profile: DVD-ROM
Revision: 1.14
Serial number: AFDL405553WL
Disc Information
Label: THE_WRESTLER
Timestamp: 2009-07-13 18:17:46
Protection: CSS/CPPM
Data capacity: 7.72 Gb
Disc type: DVD-ROM
Disc size: 120mm
Maximum read rate: 10.08 Mbps [1x]
Number of layers: 2 (OTP)
Revision: 1.14
Disc Information
Label: THE_WRESTLER
Disc type: DVD-ROM
Disc size: 120mm
PM sent.daughtersofdarkness wrote: Fri Dec 19, 2025 3:04 pm Hey @Coopervid
Revision: 1.14
PM sent.SCloop wrote: Sun Dec 21, 2025 3:55 pm I would appreciate assistance in enabling UHD disks on this drive. Thank you in advance.
OS device name: G:
Revision: 1.14
PM sent.Fredbj wrote: Sun Dec 21, 2025 7:42 pm Hello @Coopervid
Revision: 1.14
PM sent.kobayashison wrote: Sun Dec 21, 2025 8:00 pm Same as the others! Thank you in advance!
Revision: 1.14
Disc Information
Label: THE_WRESTLER
Disc type: DVD-ROM
Disc size: 120mm
DannyR2D2
Here is mine.
Revision: 1.14
Serial number: BCDL478372WL
Highest AACS version: 78
Revision: 1.14
