Anyone elses copy of TMNT 2 4K by Arrow not playing in their Pioneer BDR-XS07UHD?
InTheZoneAC
Post by InTheZoneAC » Sat Dec 13, 2025 4:20 am
This movie and the original simpsons movie on bluray are the only 2 movies to never actually spin up in my external player for makemkv. Will literally sit dead in the player for several seconds before ejecting.
Plays just fine in my LG UBK90. My Pioneer is on 1.01. Is there anything I can do for this drive to get it to read this one single movie?
Re: Anyone elses copy of TMNT 2 4K by Arrow not playing in their Pioneer BDR-XS07UHD?
Post by dcoke22 » Mon Dec 15, 2025 5:55 am
Have you tried gently cleaning the disc?
hoth80
Post by hoth80 » Mon Dec 15, 2025 6:26 am
I have many issue with this disc. Three drive each have problem. Pioneer drive different model.
1. Disc not seen by drive.
2. Cleaning.
3. Many remove and clean and insert.
4. One time drive see disc.
MakeMKV fail error:
001012:0000 udf: 	node fe/efe failed!
Xreveal crash
5. More remove and clean and insert
6. One more time drive see disc.
7. Xreveal rip. Is clean? Unknown. MakeMKV fail.
8. Remove insert 25 time. Drive never see disc again.
InTheZoneAC
Post by InTheZoneAC » Mon Dec 15, 2025 10:44 am
It's a mint 4k disc that works in my standalone player.
LeBeauLuc
Post by LeBeauLuc » Mon Dec 15, 2025 11:55 am
I own the same player and I am having the same issue as you on a brand new and flawless disc.
Tetsujin
Post by Tetsujin » Tue Dec 16, 2025 6:04 pm
I had a hell of a time getting this disc (TMNT 2 specifically) to rip. The other two movies in that set went quickly and flawlessly.
At first I couldn't even get the disc to initialize in my Billy-bought BDR212 (makemkv had been open before I put the disc in.) So I threw it in my UB820 and it played fine. While I was doing that, I restarted my computer, then I let the disc initialize in windows first, and then opened it in makemkv. It repeatedly threw a scsi error while initializing. I don't remember the specific error was but it had to do with *write* media being invalid (an error type I'd never seen before, and I have had a couple of generally unreadable discs in the past...) but eventually (after 2-3 minutes) it somehow ... got through? ... and then the disc ripped cleanly as if nothing had happened, at full speed for the drive (4.0x).
Couldn't tell you what happened, but it made me pucker a little bit.
mirrorworld
Post by mirrorworld » Wed Dec 17, 2025 7:38 am
Yes. I have the same drive and TMNT 2 isn't reading either. Both 1 and 3 work fine.
Ryan0503
Post by Ryan0503 » Thu Dec 18, 2025 2:06 pm
Same issue. Disc try's to read for a bit then ejects. 1 and 3 worked with no issues. Going to try cleaning it really good today and see if I can get any progress.
1wayjonny
Post by 1wayjonny » Thu Dec 18, 2025 10:58 pm
TMNT 2 is ripping and playing fine but #1 1990 is crashing plex on Windows an AppleTV
https://www.reddit.com/r/PleX/comments/ ... rom_arrow/
Topspin14m
Post by Topspin14m » Fri Dec 19, 2025 10:06 pm
I cannot rip the second file (with surround sound rather than stereo) from TMNT 1. Keeps erroring out. Disk looks flawless so no idea what's wrong...
Mart2025
Post by Mart2025 » Sun Dec 21, 2025 9:52 pm
Exact same issue for me: same drive and TMNT 2 isn't reading. Both 1 and 3 work fine.
zaqqaz6917
Post by zaqqaz6917 » Tue Dec 23, 2025 4:55 am
Pioneer S13UBK
No issues with any of the 3 disks, all rip fine to iso with latest versions of Xreveal and keydb.
