PM sent.nico8516 wrote: Mon Dec 15, 2025 10:19 pm Hello. I have a brand new Asus BW-16D1X-U and would like it to support UHD. Can someone help?
OS device name: \Device\CdRom2
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: XXXXXXXXXXXX
Firmware date: 2020-07-21
Highest AACS version: 77
Drive platform: RS8F00
Firmware version: E113/ID76
Thanks in advance.
Asus BW-16D1X-U
Re: Asus BW-16D1X-U
Serialkiller5150
Re: Asus BW-16D1X-U
just got the asus BW-16D1x-u trying to figure out what I need to make it work with uhd. Thanks
OS device name: F:
Current profile: DVD-ROM
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Highest AACS version: 15
OS device name: F:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Re: Asus BW-16D1X-U
Just to be verify before I flash this drive.
MakeMKV returned the following:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
But when I went to flash it with BDRFlash (BDR-212U firmware), it says that the drive is a BDR-209MBK.
Is the BDR-212U firmware compatible with my drive, or should I be using a BDR-209MBK v3 firmware (which I don't have).
Sorry for the questions. I just wanted to be sure.
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Re: Asus BW-16D1X-U
You are cross-flashing it to 212U firmware to enable UHD readability.nico8516 wrote: Wed Dec 17, 2025 4:34 am Just to be verify before I flash this drive.
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Re: Asus BW-16D1X-U
Thanks for the quick response. I flashed the drive and it was able to read a UHD disk.
Thanks very much!
Thanks very much!
Re: Asus BW-16D1X-U
PM sent.Serialkiller5150 wrote: Tue Dec 16, 2025 9:43 pm just got the asus BW-16D1x-u trying to figure out what I need to make it work with uhd. Thanks
OS device name: F:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
magictoaster
Re: Asus BW-16D1X-U
Hi. I just received a new Asus BW-16D1X-U. Can someone help me make it support UHD? Thanks!
OS device name: /dev/sr0
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Re: Asus BW-16D1X-U
PM sent.magictoaster wrote: Thu Dec 18, 2025 7:41 pm Hi. I just received a new Asus BW-16D1X-U. Can someone help me make it support UHD? Thanks!
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Re: Asus BW-16D1X-U
Can I get this PM that you've been sending out to people Coopervid? I've got the same drive. Thanks in advance!Coopervid wrote: Thu Dec 18, 2025 10:21 pmPM sent.magictoaster wrote: Thu Dec 18, 2025 7:41 pm Hi. I just received a new Asus BW-16D1X-U. Can someone help me make it support UHD? Thanks!
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Re: Asus BW-16D1X-U
Post your own Makemkv info.wakowiio wrote: Thu Dec 18, 2025 10:25 pmCan I get this PM that you've been sending out to people Coopervid? I've got the same drive. Thanks in advance!Coopervid wrote: Thu Dec 18, 2025 10:21 pmPM sent.magictoaster wrote: Thu Dec 18, 2025 7:41 pm Hi. I just received a new Asus BW-16D1X-U. Can someone help me make it support UHD? Thanks!
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Re: Asus BW-16D1X-U
Here you go:
OS device name: I:
Manufacturer: ASUS
Product: BW-16D 1X-U
Revision: E113
Serial number:
Bus encryption flags: 18
Highest AACS version: 12
OS device name: I:
Manufacturer: ASUS
Revision: E113
Serial number:
Re: Asus BW-16D1X-U
PM sent.wakowiio wrote: Thu Dec 18, 2025 10:51 pm Here you go:
OS device name: I:
Manufacturer: ASUS
Revision: E113
Serial number:
magictoaster
Re: Asus BW-16D1X-U
Thanks! Donation sent!Coopervid wrote: Thu Dec 18, 2025 10:21 pmPM sent.magictoaster wrote: Thu Dec 18, 2025 7:41 pm Hi. I just received a new Asus BW-16D1X-U. Can someone help me make it support UHD? Thanks!
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Re: Asus BW-16D1X-U
My LG WH16NS40 just died, so I'm going to have to purchase something. Pricing and availability varies, but the local Microcenter has Asus BW-16D1X-U in stock for the same price I'm seeing online. So I was thinking of picking one up after reading this thread.
It looks like the most recent posters are getting a Pioneer drive in the enclosure when purchasing an Asus BW-16D1X-U. And while the firmware and process isn't posted, it is flashable (and usable with MakeMKV) with PM being sent. Is that correct?
EDIT: And can this drive be taken out of the external enclosure and put internally? (I do have 5.25" external bays)
Re: Asus BW-16D1X-U
Correct. But if it's a Pioneer drive inside the firmware must be older than Dec. 2022 to enable UHD capability. Buy it and if the firmware is younger return it. If a LG is inside you can flash it with the tools available in the forum.KidJoe wrote: Fri Dec 19, 2025 3:27 pm My LG WH16NS40 just died, so I'm going to have to purchase something. Pricing and availability varies, but the local Microcenter has Asus BW-16D1X-U in stock for the same price I'm seeing online. So I was thinking of picking one up after reading this thread.
