PM is coming.gnafuthegreat wrote: Mon Dec 15, 2025 4:37 pmThis appears to match what others have had success with, so I'm hopeful! I would like to note I'm on Linux and I'm very comfortable using `sdftool` if it's just a matter of flashing a particular file. I just haven't been able to find that information for this specific drive anywhere. I look forward to any guidance you can provide!Code: Select all
Drive Information OS device name: /dev/sr1 Manufacturer: PIONEER Product: BD-RW BDR-XD05 Revision: 3.01 Serial number: *snip* Firmware date: 2014-12-26 Bus encryption flags: 1B LibreDrive Information Status: Enabled Drive platform: RS8231 Firmware name: PIONEER BDR-XD05 Firmware type: Original (unpatched) Firmware version: 3.01/ID34 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
Is my pioneer BDR-XD05s flashable?
Re: Is my pioneer BDR-XD05s flashable?
BluegrassGeek
OS device name: I:
Revision: 3.10
Serial number: SEDL101306UC
Firmware date: 2017-06-22
Drive platform: RS8232
Firmware version: 3.10/ID34
Unrestricted read speed: YesRe: Is my pioneer BDR-XD05s flashable?
PM sent.BluegrassGeek wrote: Tue Dec 16, 2025 10:55 pmWas hoping to see if this model could possibly be flashed.Code: Select all
Drive Information OS device name: I: Current profile: BD-ROM Manufacturer: PIONEER Product: BD-RW BDR-XD05 Revision: 3.10 Serial number: SEDL101306UC Firmware date: 2017-06-22 Bus encryption flags: 1B LibreDrive Information Status: Enabled Drive platform: RS8232 Firmware name: PIONEER BDR-XD05 Firmware type: Original (unpatched) Firmware version: 3.10/ID34 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
Email me that drive info sectiongnafuthegreat wrote: Mon Dec 15, 2025 4:37 pmThis appears to match what others have had success with, so I'm hopeful! I would like to note I'm on Linux and I'm very comfortable using `sdftool` if it's just a matter of flashing a particular file. I just haven't been able to find that information for this specific drive anywhere. I look forward to any guidance you can provide!Code: Select all
FYI you need windows to flash
gnafuthegreat
Thanks, Coopervid already helped me out. I appreciate you both!Billycar11 wrote: Wed Dec 17, 2025 11:47 amEmail me that drive info sectiongnafuthegreat wrote: Mon Dec 15, 2025 4:37 pmThis appears to match what others have had success with, so I'm hopeful! I would like to note I'm on Linux and I'm very comfortable using `sdftool` if it's just a matter of flashing a particular file. I just haven't been able to find that information for this specific drive anywhere. I look forward to any guidance you can provide!Code: Select all
Hi everyone. I've flashed other drives successfully with the command line tool but I'm also struggling to find the right firmware for this Pioneer drive. Would someone be willing to assist? I would truly appreciate it!
Here is my info:
Here is my info:
OS device name: F:
Revision: 3.01
Serial number:
Highest AACS version: 81
Drive platform: Pioneer RS8231
Firmware version: ID35Re: Is my pioneer BDR-XD05s flashable?
PM sent.amstrick wrote: Fri Dec 19, 2025 7:24 pm Hi everyone. I've flashed other drives successfully with the command line tool but I'm also struggling to find the right firmware for this Pioneer drive. Would someone be willing to assist? I would truly appreciate it!
Here is my info:
Drive Information OS device name: F: Manufacturer: PIONEER Product: BD-RW BDR-XD05 Revision: 3.01 Serial number: Firmware date: 2014-12-26 Bus encryption flags: 1B Highest AACS version: 81 LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS8231 Firmware version: ID35
Thank you so much!
heavenlytunes
Hi everyone, here is the info on my drive. Seems to be the same info as other. Appreciate the help!
OS device name: /dev/sr0
Revision: 3.01
Serial number: ****
Revision: 3.01
Serial number: ****
Good evening! Is it possible that my BDR-XD05 slim/usb drive may also be flashed? Thanks in advance!!
Revision: 3.10
Serial number: RFDL081610UC
Highest AACS version: 76
PM sent.heavenlytunes wrote: Mon Dec 22, 2025 11:25 pm Hi everyone, here is the info on my drive. Seems to be the same info as other. Appreciate the help!
Revision: 3.01
Serial number: ****
PM sent.awjennin wrote: Tue Dec 23, 2025 1:36 am Good evening! Is it possible that my BDR-XD05 slim/usb drive may also be flashed? Thanks in advance!!
Drive Information OS device name: \Device\CdRom0 Current profile: BD-ROM Manufacturer: PIONEER Product: BD-RW BDR-XD05 Revision: 3.10 Serial number: RFDL081610UC Firmware date: 2017-06-22 Bus encryption flags: 1B Highest AACS version: 76 LibreDrive Information Status: Enabled Drive platform: RS8232 Firmware name: PIONEER BDR-XD05 Firmware type: Original (unpatched) Firmware version: 3.10/ID34 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes No disc inserted
Maybe I'm not understanding this, but I thought I'd be able to read UHD discs with my drive:
Revision: 3.10
Serial number:
Am I missing something?
Revision: 3.10
Serial number:
PM sent. It needs to be flashed.shawmaan wrote: Wed Dec 24, 2025 2:11 pm Maybe I'm not understanding this, but I thought I'd be able to read UHD discs with my drive:
Revision: 3.10
Serial number:
franklinkayq
Revision: 3.10
Serial number: RADL136086UC
Highest AACS version: 68
Revision: 3.10
