New to 4k ripping question
grappler1999
Post by grappler1999 »
I’m new to ripping discs and recently finished ripping my entire Blu-ray collection (about 13 TB total). I’m now looking to start ripping my 4K Ultra HD collection and have a few questions:
Does the LG BP60NB10 external slim 4K Ultra HD drive work for ripping to MKV format? The listing states that it has been flashed with the correct firmware.
Will I be able to rip 4K Ultra HD discs on a Mac?
Will 4K MKV rips maintain the same quality as the original disc? My Blu-ray rips turned out very well, and I’m hoping for similar results with 4K.
Thank you for any guidance.
keydb_helper
Re: New to 4k ripping question
Post by keydb_helper »
grappler1999 wrote: Tue Dec 16, 2025 9:40 pm Does the LG BP60NB10 external slim 4K Ultra HD drive work for ripping to MKV format? The listing states that it has been flashed with the correct firmware.
Yes, that firmware version should work properly with 4K/UHD discs
grappler1999 wrote: Tue Dec 16, 2025 9:40 pm Will I be able to rip 4K Ultra HD discs on a Mac?
Yes
grappler1999 wrote: Tue Dec 16, 2025 9:40 pm Will 4K MKV rips maintain the same quality as the original disc?
Yes. MakeMKV does not re-encode anything so the quality will be identical. It is functionally the same as moving an object from one box to another, slightly smaller box.
Public KeyDB Disc Submissions KeyDB Download
KeyDB Priority List
