Public KeyDB Disc Submissions
benpollard
Post by benpollard »
Disc type: Blu-Ray
Disc dump filename: MKB_v82_DOGMA_BCEA.tgz
Drive: BD-RW BDR-XS07U
Drive firmware: 1.02/ID05
LibreDrive status: Enabled
Did you sync the public keydb within the last 15 minutes? YES
Have you verified that all submission links are accessible in incognito/private browsing? YES
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://www.dropbox.com/scl/fi/meyp1rce ... fee1m&dl=0
Disc dump link: https://www.dropbox.com/scl/fi/93ewps8a ... onhfb&dl=0
Disc type: UHD
Disc dump filename: MKB20_v82_Dogma_UHD_ED9E.tgz
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://www.dropbox.com/scl/fi/dcr35sa9 ... upja7&dl=0
Disc dump link: https://www.dropbox.com/scl/fi/ds04cft0 ... u9ntw&dl=0
Rushton
Post by Rushton »
keydb_helper wrote: Mon Dec 15, 2025 12:44 pm Thanks for following the template so carefully Rushton. Your disc has been added to the public keydb.
Thank you for uploading it to the database. It appears to be working here.
Sorry if this has been asked before, but I'm finding inconsistent information online.
What process are you using to convert the disc dumps into entries in keydb.cfg? I'm interested in learning how to do this on my own.
csbond2
Post by csbond2 »
Disc type: UHD
Disc dump filename: MKB20_v77_Riddick_E7B7.tgz (Steelbook)
Drive: BD-RE BP60NB10
MKB_RO.inf link: https://drive.google.com/file/d/1GxutTI ... sp=sharing.
Disc dump:https://drive.google.com/file/d/1XJ170M ... sp=sharing
That_Mac_Guy
Post by That_Mac_Guy »
Disc type: UHD
Disc dump filename:MKB20_v82_ARCANE_SEASON_2_-_DISC_1_FFC6.tgz
Disc dump filename:MKB20_v82_ARCANE_SEASON_2_-_DISC_2_7D15.tgz
Disc dump filename:MKB20_v82_ARCANE_SEASON_2_-_DISC_3_0EB7.tgz
Drive firmware: 1.02 (I think this is correct)
MKB_RO.inf link1: https://drive.google.com/file/d/16G1VFU ... sp=sharing
MKB_RO.inf link2: https://drive.google.com/file/d/1B06tw8 ... drive_link
MKB_RO.inf link3: https://drive.google.com/file/d/1Mw6_p0 ... drive_link
Disc dump link1: https://drive.google.com/file/d/1_Mj8bs ... drive_link
Disc dump link2: https://drive.google.com/file/d/1aSlxg2 ... drive_link
Disc dump link3: https://drive.google.com/file/d/1jmkEX_ ... drive_link
Toad King
Post by Toad King »
Disc type: UHD
Disc dump filename: MKB20_v82_Cloud_Atlas_A6EA
Drive: BD-RE WH16NS60
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): Not needed
Disc dump link: https://drive.google.com/file/d/194gZXN ... K3u3Y/view
Toad King
Post by Toad King »
csbond2 wrote: Mon Dec 15, 2025 6:44 pm MKB_RO.inf link: Don't know how to get this.
Read the first post. You need to copy that file directly from the disc.
marcuse111
Post by marcuse111 »
Disc type: UHD
Disc dump filename: MKB20_v76_UHD_JOLT_D99B.tgz
MKB_RO.inf link https://limewire.com/d/ZVZqw#wHrABv9FxP
Disc dump link: https://limewire.com/d/ZVZqw#wHrABv9FxP
bcrush
Post by bcrush »
Disc type: UHD
Disc dump filename: MKB20_v82_11_DAYS_11_NIGHTS_@_A362.tgz
Drive: LG BU40N
Drive firmware: 1.00
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1tdcyPQ ... sp=sharing
Disc dump link: https://drive.google.com/file/d/12xbHHt ... HkgGA/view
keydb_helper
Post by keydb_helper »
treatsbyjay wrote: Mon Dec 15, 2025 10:22 am I knew mine wouldn't be that easy haha. I've followed your instructions, here's the new dump MakeMKV created.
Hey Jay, thanks for following up but your disc variant was added to the keydb a couple of days ago thanks to the equivalent disc dump file provided by the user Baden.
jisoo9707 wrote: Mon Dec 15, 2025 1:08 pm Hello
This is my dump and MKB_RO.inf file
plz help me
Hey jisoo9707, your disc dump files seems to be structured quite strangely. Did you happen to edit or modify the file? Was it created from a commercial/pressed disc? Or does it correspond to a BDAV disc created with a Blu-ray recorder?
Hey csbond2, thanks for the honesty. Luckily for you that file isn't required for your particular disc as the media key was already present in the keydb record of a different disc variant. Grab the very latest keydb and you should be good to go,
benpollard wrote: Mon Dec 15, 2025 1:53 pm Disc dump filename: MKB_v82_DOGMA_BCEA.tgz
Hey Ben, thanks for the submission. Your Pioneer disc drive is fine for 1080p discs but it can't be used to generate UHD keydb entries from scratch. Luckily for you, the user FonduemangVI posted a suitable disc dump file created with an LG drive in the Dogma title thread so both of your discs have been added to the public keydb.
bcrush wrote: Tue Dec 16, 2025 1:11 am Disc dump filename: MKB20_v82_11_DAYS_11_NIGHTS_@_A362.tgz
Hey bcrush, thanks for following the template but your disc was added to the public keydb on November 20. Please make sure you try the latest keydb before posting in the future.
Thanks to everyone else who provided suitable, new disc dump files. The following discs have been added to the public keydb:
MKB20_v82_BUGONIA_UPK75_00CC
MKB_v82_DOGMA_BCEA
Public KeyDB Disc Submissions KeyDB Download
marcuse111
Thank you!
GazeTail
Post by GazeTail »
keydb_helper
GazeTail wrote: Tue Dec 16, 2025 4:33 am Dogma UHD
Don't waste my time. Your disc variant was added to the public keydb on November 26. Read the first post of this thread.
qqac8
Post by qqac8 »
Disc type:BD
Disc dump filename:MKB_v82_サイレント・ウィッチ_沈黙の魔女の隠しごと_3_8CD2
Drive: BD-RE BH16NS58
Drive firmware: 1.01
LibreDrive status: True
Did you sync the public keydb within the last 15 minutes?: Yes
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://transfer.it/t/eA8LbI93xZJC (Copied from disk)
Disc dump link: https://transfer.it/t/LIbSKZ1VCLIa
hj1118
Post by hj1118 »
Disc type: Blu-ray
Disc dump filename: MKB20_v77_The_Sound_of_Music_BCE8
MKB_v82_GYROAXIA_mini_Album「REVOLVER」【Blu-ray付生産限定盤】_F116
MKB_RO.inf link: https://drive.google.com/file/d/1km_UHo ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1LbltsN ... sp=sharing
pingpong
Post by pingpong »
Disc type: Blu-ray
Disc dump filename: MKB_v82_舞台『刀剣乱舞』士伝_真贋見極める眼_本編DISC_源清麿_部隊編入ver_FAE4
Drive: LG BP60NB10
LibreDrive status: Possible
MKB_RO.inf link: https://drive.google.com/file/d/1fk6Mk0 ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1vtgvmn ... sp=sharing
Disc type: Blu-ray
Disc dump filename: MKB_v82_舞台『刀剣乱舞』士伝_真贋見極める眼_特典DISC_A32C
Drive: LG BP60NB10
MKB_RO.inf link: https://drive.google.com/file/d/1nVvb0c ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1Jn5rVn ... sp=sharing
