Public KeyDB Disc Submissions
Disc type: UHD
Disc dump filename: MKB20_v82_CATCH_ME_IF_YOU_CAN_32D1.tgz
Drive: BU40N
Drive firmware: 1.00
LibreDrive status: Enabled
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1n_z6B5 ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1kXNNl7 ... sp=sharing
Drive: BU40N
treatsbyjay
I knew mine wouldn't be that easy haha. I've followed your instructions, here's the new dump MakeMKV created.keydb_helper wrote: ↑Sun Dec 14, 2025 12:52 amHey Jay, thanks for submitting that disc dump file. You did everything right, but MakeMKV seems to have run into an issue whilst generating that disc dump file.treatsbyjay wrote: ↑Sat Dec 13, 2025 12:25 pmFirst time submitting so hope I got all this right!
Disc dump filename: MKB20_v82_Thunderbirds_4K_Collectors_Edition_3D88.tgz
Could you please move that dump file out of MakeMKV's data directory, completely power off your disc drive, restart your computer and generate a new disc dump file? Feel free to post the newly generated disc dump file to this thread whenever you get a chance.
There is no need to change any MakeMKV setting or drive firmware. I believe the cause was either a transient issue or possibly a quirk of your particular disc.
https://www.mediafire.com/file/8ntnzbio ... 8.tgz/file
keydb_helper
Hey Tobisatsu, thanks for the new submission. Both of your discs have been added to the public keydb.
Thanks for following the template so carefully Rushton. Your disc has been added to the public keydb.
Your disc was added to the public keydb on November 27. The intro to your post is also completely irrelevant for the purposes of the keydb.
By choosing to not read the opening post of this thread you have wasted both my time and your own. Please read it before posting here again. If any aspect of the first post is still unclear to you after trying to read it, please PM me. I won't actually read your PM, but I will respond to you.
Hello
This is my dump and MKB_RO.inf file
plz help me
https://drive.google.com/file/d/1zyRssq ... sp=sharing
https://drive.google.com/file/d/1_z0NB7 ... sp=sharing
plz help me
benpollard
Disc type: Blu-Ray
Disc dump filename: MKB_v82_DOGMA_BCEA.tgz
Drive: BD-RW BDR-XS07U
Drive firmware: 1.02/ID05
Did you sync the public keydb within the last 15 minutes? YES
Have you verified that all submission links are accessible in incognito/private browsing? YES
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://www.dropbox.com/scl/fi/meyp1rce ... fee1m&dl=0
Disc dump link: https://www.dropbox.com/scl/fi/93ewps8a ... onhfb&dl=0
Disc type: UHD
Disc dump filename: MKB20_v82_Dogma_UHD_ED9E.tgz
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://www.dropbox.com/scl/fi/dcr35sa9 ... upja7&dl=0
Disc dump link: https://www.dropbox.com/scl/fi/ds04cft0 ... u9ntw&dl=0
Disc type: UHD
Thank you for uploading it to the database. It appears to be working here.keydb_helper wrote: ↑Mon Dec 15, 2025 12:44 pmThanks for following the template so carefully Rushton. Your disc has been added to the public keydb.
Sorry if this has been asked before, but I'm finding inconsistent information online.
What process are you using to convert the disc dumps into entries in keydb.cfg? I'm interested in learning how to do this on my own.
Disc type: UHD
Disc dump filename: MKB20_v77_Riddick_E7B7.tgz (Steelbook)
Drive: BD-RE BP60NB10
MKB_RO.inf link: https://drive.google.com/file/d/1GxutTI ... sp=sharing.
Disc dump:https://drive.google.com/file/d/1XJ170M ... sp=sharing
That_Mac_Guy
Disc type: UHD
Disc dump filename:MKB20_v82_ARCANE_SEASON_2_-_DISC_1_FFC6.tgz
Disc dump filename:MKB20_v82_ARCANE_SEASON_2_-_DISC_2_7D15.tgz
Disc dump filename:MKB20_v82_ARCANE_SEASON_2_-_DISC_3_0EB7.tgz
Drive firmware: 1.02 (I think this is correct)
MKB_RO.inf link1: https://drive.google.com/file/d/16G1VFU ... sp=sharing
MKB_RO.inf link2: https://drive.google.com/file/d/1B06tw8 ... drive_link
MKB_RO.inf link3: https://drive.google.com/file/d/1Mw6_p0 ... drive_link
Disc dump link1: https://drive.google.com/file/d/1_Mj8bs ... drive_link
Disc dump link2: https://drive.google.com/file/d/1aSlxg2 ... drive_link
Disc dump link3: https://drive.google.com/file/d/1jmkEX_ ... drive_link
Disc type: UHD
Disc dump filename: MKB20_v82_Cloud_Atlas_A6EA
Drive: BD-RE WH16NS60
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): Not needed
Disc dump link: https://drive.google.com/file/d/194gZXN ... K3u3Y/view
marcuse111
Disc type: UHD
Disc dump filename: MKB20_v76_UHD_JOLT_D99B.tgz
MKB_RO.inf link https://limewire.com/d/ZVZqw#wHrABv9FxP
Disc dump link: https://limewire.com/d/ZVZqw#wHrABv9FxP
Disc type: UHD
Disc dump filename: MKB20_v82_11_DAYS_11_NIGHTS_@_A362.tgz
Drive: LG BU40N
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1tdcyPQ ... sp=sharing
Disc dump link: https://drive.google.com/file/d/12xbHHt ... HkgGA/view
Drive: LG BU40N
keydb_helper
Hey Jay, thanks for following up but your disc variant was added to the keydb a couple of days ago thanks to the equivalent disc dump file provided by the user Baden.treatsbyjay wrote: ↑Mon Dec 15, 2025 10:22 amI knew mine wouldn't be that easy haha. I've followed your instructions, here's the new dump MakeMKV created.
Hey jisoo9707, your disc dump files seems to be structured quite strangely. Did you happen to edit or modify the file? Was it created from a commercial/pressed disc? Or does it correspond to a BDAV disc created with a Blu-ray recorder?
Hey csbond2, thanks for the honesty. Luckily for you that file isn't required for your particular disc as the media key was already present in the keydb record of a different disc variant. Grab the very latest keydb and you should be good to go,
Hey Ben, thanks for the submission. Your Pioneer disc drive is fine for 1080p discs but it can't be used to generate UHD keydb entries from scratch. Luckily for you, the user FonduemangVI posted a suitable disc dump file created with an LG drive in the Dogma title thread so both of your discs have been added to the public keydb.benpollard wrote: ↑Mon Dec 15, 2025 1:53 pmDisc dump filename: MKB_v82_DOGMA_BCEA.tgz
Hey bcrush, thanks for following the template but your disc was added to the public keydb on November 20. Please make sure you try the latest keydb before posting in the future.
Thanks to everyone else who provided suitable, new disc dump files. The following discs have been added to the public keydb:
MKB20_v82_BUGONIA_UPK75_00CC
MKB_v82_DOGMA_BCEA
marcuse111
Thank you!
