I have a Mac operating on the Tahoe 26.1 OS. Lately it has been giving me the message- "failed to open disc" after the log shows it has decoded all the titles. Is there some setting I am missing? I tried on several discs that have worked before- getting the same message. I know the DVD player is working- it opens the disc in DVD player. I would appreciate any help. Thanks.
Pasting log below:
MakeMKV v1.18.2 darwin(arm64-release) started
Optical drive "BD-RE PIONEER BD-RW BDR-XD05 3.01 OEDL058244UCd" opened in OS access mode.
Using LibreDrive mode (v02.1 id=5FB5DFEE2318)
Error 'OS error - (ipc/send) invalid destination port' occurred while reading 'BD-RE PIONEER BD-RW BDR-XD05 3.01 OEDL058244UC' at offset '46594048'
Cells 1-1 were removed from title start
Cells 47-47 were removed from title end
Title #1 declared length is 1:40:18 while its real length is 0:00:00 - assuming fake title
Title #2 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #3 has length of 102 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #4 has length of 61 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #5 has length of 64 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #6 has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #13 has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #14 has length of 80 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #16 has length of 49 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Cells 1-4 were removed from title start
Cells 6-6 were removed from title end
Title #17 (0:02:27) was skipped due to navigation error
Title #18 has length of 48 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #19 has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #20 has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Failed to open
Re: Failed to open
Let the OS first read the disc. Only then start Makemkv.
markcw98
Re: Failed to open
Thanks for the response. I am not sure what you mean by making sure the OS first reads the disc. The disc shows on my desktop and DVD player reads it and opens up automatically. This always happens first- then I close the player and open MKV. This is the same process I have used in the past with no issue.
I tried with the player still open and got this result...
log file
Error 'OS error - (ipc/send) invalid destination port' occurred while reading 'BD-RE PIONEER BD-RW BDR-XD05 3.01 OEDL058244UC' at offset '75776'
udf: UDF mount: reading in reserve VDS extent
Error 'OS error - (ipc/send) invalid destination port' occurred while reading 'BD-RE PIONEER BD-RW BDR-XD05 3.01 OEDL058244UC' at offset '98304'
udf: UDF mount: error reading volume space
Error 'OS error - (ipc/send) invalid destination port' occurred while reading 'BD-RE PIONEER BD-RW BDR-XD05 3.01 OEDL058244UC' at offset '32768'
log file
Re: Failed to open
It seems like maybe the drive isn't getting enough power. Is the drive powered via USB-A? Are both connectors plugged into high powered ports? Can you use a power supply with the drive?
markcw98
Re: Failed to open
dcoke22 wrote: Thu Dec 18, 2025 1:45 pm It seems like maybe the drive isn't getting enough power. Is the drive powered via USB-A? Are both connectors plugged into high powered ports? Can you use a power supply with the drive?
I think you nailed it. This has not happened before but it seems my external drive is working fine with both connections plugged into USB ports. I do not understand why this changed but appreciate the suggestion.
Thank you
Mark
