Star Wars The Clone Wars Season 3 failed to rip properly
dcv74656
Post by dcv74656 »
I am using makemkv 1.7.2, running on Fedora 14. I am just working with the first disc. It rips a total number of 10 titles, which seems one more than it should be (7 titles, 2 special features are on this disc), and the contents of the tracks is not what it should be. Four of the ten tracks are the same, a picture of the cover and the audio is the theme song. The first track and the forth track has multiple episodes within it (as far as I can tell they are duplicates of one another, 13.8GB). I have processed the discs from season 1 and 2, they worked flawlessly.
Let me know and I can make the dump files available
Re: Star Wars The Clone Wars Season 3 failed to rip properly
Post by mike admin »
Please see if any messages show up if you enable debug log per http://www.makemkv.com/faq/item/8/catid/6
dcv74656
Post by dcv74656 »
I have attached the log file.
MakeMKV_log.txt
(11.58 KiB) Downloaded 672 times
Please send CLPI and MPLS files from this disc to support@makemkv.com .
dcv74656
Post by dcv74656 »
I have sent a total of 3 emails - there is a limit of 50 attachments per email.
Let me know if there is any issues and I will resend.
nudenutnz
Post by nudenutnz »
I am also having an issue with converting a Blu Ray disc (Star Wars - The Clone Wars) to an .mkv file. I have tried this on 2 different machines running Win 7 SP1, with the same result. The disc is brand new so that is not an issue. I will send the details requested of "dcv74656" to the "support@makemkv.com" mail box to assist in troubleshooting. If you need anything else please let me know.
dcv74656
Post by dcv74656 »
Is there any solution or is there anything else I can provide to help?
Thanks!!
gchapman1701
Post by gchapman1701 »
I have the same issue as they reported. Anything new on this?
dcv74656
Post by dcv74656 »
I have upgraded to 1.7.3 and 1.7.4 and have experienced the same issue.
What other information can I provide to help solve this issue?
This looks like both bug in MakeMKV and extremely badly mastered disc ( perhaps on purpose ). The bug should be fixed in the next version, but you'll still get a single gigantic file with all episodes concatenated.
nudenutnz
Post by nudenutnz »
Error still evident in v1.7.6. Do you need any further info?
nudenutnz
Post by nudenutnz »
Error still evident in v1.7.7.
As I've mentioned earlier, the single "one huge" file with all concatenated episodes is unfortunately not a bug - that's how the disc is mastered. Your only option is to cut the produced MKV file with mkvtoolnix.
nudenutnz
Post by nudenutnz »
Could be talking at cross purposes here. My issue is with Star Wars The Clone Wars movie, not the TV Series which is what I think you are referring to. I realise the topic is "Star Wars The Clone Wars Season 3" but I did not want to raise another issues as this seemed to cover the problem encountered initially. Should I raise a separate issue to address the problem with the The Clone Wars movie?
gabeen
Post by gabeen »
mike admin wrote:As I've mentioned earlier, the single "one huge" file with all concatenated episodes is unfortunately not a bug - that's how the disc is mastered. Your only option is to cut the produced MKV file with mkvtoolnix.
All the episodes are seperate files on the actual blu-ray disc.
This can be fixed and was fixed by for various discs, like Weeds - Season 1: http://www.makemkv.com/forum2/viewtopic.php?t=7189
