MakeMKV on Bazzite
OtherUser47
MakeMKV on Bazzite
Post by OtherUser47 » Sun Dec 14, 2025 9:59 pm
I use Bazzite as my OS and today I tried to use MakeMKV as a Flatpak. When I start MakeMKV, the CPU usage shoots up and MakeMKV doesn't respond. I then started it via the command line (flatpak run com.makemkv.MakeMKV) and received the following error:
qt.qpa.wayland: Wayland does not support QWindow::requestActivate()
Is there a workaround for this?
Thanks a lot! BR
flagcourier
Re: MakeMKV on Bazzite
Post by flagcourier » Sun Dec 28, 2025 2:27 am
It sound like your XWayland session isn't properly launching.
Make sure you're on the latest image by running:
ujust update
...and restarting your computer after.
OtherUser47
Post by OtherUser47 » Mon Jan 05, 2026 5:04 pm
Thanks for the tip. My system is up to date. Unfortunately, I still haven't solved the problem :-/
%%%%%%%% %%%%%%%%%%%%%% 󱋩  bazzite:stable 
%%%%%%%%% %%%%%%%%%%%%%%%% 󰣛  Bazzite
%%%%%%%%% %%%%%%%%%%%%%%%###   Linux 6.17.7-ba22.fc43.x86_64
%%%%%%%%% %%%%%%%%%%%%%###### 󰅐  2 days, 7 hours, 26 mins
== =========##### 󰻠  AMD Ryzen 7 7800X3D (16) @ 5.05 GHz
%%%%%%%%% %%%%%%%####======##### 󰍛  AMD Radeon RX 9070 XT (64) @ 2.46 GHz (951.84 MiB / 15.84 GiB, 6%) [Discrete]
%%%%%%%%% %%%%%#######=====##### 󰍛  AMD Ryzen 7 7800X3D 8-Core Processor (2) @ 2.20 GHz (15.90 MiB / 488.17 MiB, 3%) [Integrated]
%%%%%%%%% %%%#########=====#####   11.51 GiB / 61.94 GiB (19%)
%%%%%%%%% %%##########=====#####   1.21 TiB / 1.82 TiB (67%) - btrfs
%%%%%%%%%====###########=====######   2.04 MiB / 1.79 TiB (0%) - ext4
%%%%%%%%====#########======###### 󰍹  2560x1440 @ 60 Hz in 27" [External]
%%%%###===============####### 󰕮  KDE Plasma 6.5.4
%#######==========#########   KWin (Wayland)
#######################   bash 5.3.0
###################   Ptyxis 49.2
########### 󰏖  2882 (rpm), 56 (flatpak)
