failed to save error when converting iso to mkv
When I atempt to convert a bluray disc to mkv i get the following error. This error occurs if i am trying to convert from ISO or from burned disc. It occurs for me in Windows and in Linux (ubunutu). Any help would be appreciated. I did enter the new (valid through april) key, but that did not seem to have any effect.
I'm not sure if it's worth mentioning or not, but I can stream the file and am able to fully play the movie using xbmc.
MakeMKV v1.7.2 win(x86-release) started
Debug logging enabled, log will be saved as C:\Users\Support/MakeMKV_log.txt
DEBUG: Code 0 at 3Zk[F[fw]n[;S(@@h:121262164
AACS directory not present, assuming unencrypted disc
File 00000.mpls was added as title #0
Saving 1 titles into directory C:/Video/Star_Wars
AV synchronization issues were found in file 'C:/Video/Star_Wars/title00.mkv' (title #1)
AV sync issue in stream 1 at 0:00:00.031 with duration of 32ms : 1 early frame(s) dropped at start
DEBUG: Code 2147483647 at =wv'seh=MTO8p+qBu G:29393700
LIBMKV_TRACE: Exception: MKV_ASSERT: TimecodeDelay >= int16(0x8000) && TimecodeDelay <= int16(0x7FFF)
Failed to save title 0 to file C:/Video/Star_Wars/title00.mkv
0 titles saved, 1 failed
Here is the file info.
Title information
Source file name: 00000.mpls
Duration: 2:01:50
Chapters count: 24
Segment count: 1
Segment map: 0
File name: title00.mkv
Track information
Type: Video
Codec: Mpeg4
Resolution: 1280x720
Aspect ratio: 16:9
Frame rate: 23.976 (24000000/1001000)
Track information
Type: Audio
Language: English
Codec: Dolby Digital
Channels: 6
Sample rate: 48000
Title information
Duration: 2:01:50
Chapters count: 24
Segment count: 1
Segment map: 0
Track information
Type: Video
Codec: Mpeg4
Aspect ratio: 16:9
Track information
Type: Audio
Language: English
Channels: 6
Sample rate: 48000
Smithcraft
Re: failed to save error when converting iso to mkv
With that odd resolution, I'm wondering if this is a retail disc, or some sort of custom disc?
SC
SC
setarip_old
@Smithcraft
Hi!
1280x720 IS a conforming Blu-ray resolution... (Though far less frequently used versus 19201080)
Hi!
For Star Wars?setarip_old wrote:1280x720 IS a conforming Blu-ray resolution... (Though far less frequently used versus 19201080)
Is this for the Despecialized iso? I'm having similar problems:
Debug log started at Sat Mar 10 09:25:02 2012 , written by MakeMKV v1.7.2 win(x64-release)
001005:0000 MakeMKV v1.7.2 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\********/MakeMKV_log.txt
001003:0020 DEBUG: Code 0 at |;F$9!4w9'<_dIX[d:121262164
003305:0000 AACS directory not present, assuming unencrypted disc
003307:0000 File 00000.mpls was added as title #0
005014:0000 Saving 1 titles into directory //********/Videos
004007:0010 AV synchronization issues were found in file '//********/Videos/title00.mkv' (title #1)
004008:0010 AV sync issue in stream 1 at 0:00:00.031 with duration of 32ms : 1 early frame(s) dropped at start
001003:0020 DEBUG: Code 2147483647 at !`QAcCmf{*Gx'}XU~?!:29393700
001002:0020 LIBMKV_TRACE: Exception: MKV_ASSERT: TimecodeDelay >= int16(0x8000) && TimecodeDelay <= int16(0x7FFF)
005003:0000 Failed to save title 0 to file //********/Videos/title00.mkv
005004:0080 0 titles saved, 1 failed
Application exited at Sat Mar 10 09:31:14 2012
setarip_old
@finn1911
Instead of the .ISO image file that you created, try using your original, commercial Blu-ray disc as your initial source material...
setarip_old
@drfrank
Hi!
Hiding file titles with "*******" only leads to suspicion of innapropriate source material - which is not appreciated at this forum...
Hi!
He's not hiding the file title; he's hiding his Windows username, which is a perfectly valid privacy concern in a public forum. You really ought to take a chill pill sometimes and remember that this isn't your forum!setarip_old wrote:Hiding file titles with "*******" only leads to suspicion of innapropriate source material - which is not appreciated at this forum...[/color]
Which isn't an official release and can't therefore be purchased legallydrfrank wrote:Is this for the Despecialized iso?
Romansh, setarip,
I don't see any mention anywhere that Makemkv is only for commercial discs, nor any mention anywhere that this forum is only for commercial discs. Am I missing something?
setarip_old
@drfrank
Yes, you are.
Although formal forum rules have not yet been posted, "mike admin" (owner of the forum) has posted more than once that discussion of other-than-purchased commercial media is not acceptable at the MakeMKV forum.
It's unacceptable for at least two reasons:
1) The concept of duplicating something you don't own is unethical, at the very least
2) Supporting such activity (by allowing discussion at this forum) is an invitation to the attorneys for the studios and related companies and support organizations (such as the MPAA) to "bring the wrath of the gods" upon the forum and its owners. You have only to look at what happened to Digital Video Digest's foum, owner, and mods several years ago
Yes, you are.
Smithcraft
Fan Edits For The Win!
If it is a Fan Edit, I'd try and see if it was also released as just a file, rather than a disc image.
SC
SC
