There seems to be very low availability of drives that can rip UHD where I live.
These too can be ordered and according to the Forum people have been able to update their firmwares.
Which one should I go for? Is either of them bought today more likely to be able to be flashed?
I was reading that the Asus needs a firmware before 2022 so buying one today it could be unlikely.
Thank you for your support!
Verbatim 43890 Or ASUS SBW-06D5H-U
Re: Verbatim 43890 Or ASUS SBW-06D5H-U
If you are lucky either one could have a Pioneer drive inside which can be cross-flashed! Probably a slightly better chance of that with the 43890.TheRipped wrote: Sun Dec 14, 2025 12:40 pm There seems to be very low availability of drives that can rip UHD where I live.
TheRipped
Thank you! I will take my chances with the verbatim! Fingers crossed!
TheRipped
Got the drive and it had the guts from LG
BD-RE BU40N
did not get lucky with Pioneer but this should work!
BD-RE BU40N
zittrig
The BU40N is the best one from LG.
Enjoy it with firmware 1.03MK.
