RONNIEAST wrote: Sat Dec 13, 2025 11:44 pm My Drive says the following in MakeMKV
OS device name: F:
Manufacturer: ASUS
Product: SBW-06D2X-U
Revision: A102
Serial number:
Firmware date: 2121-06-28 13:41
Bus encryption flags: 1F
Could you assist please?
email me or marty for a flash kit
BlueRogue44 wrote: Sat Dec 13, 2025 2:19 am
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: DHDL119818WL
Firmware date: 2020-07-21
Drive platform: RS8F00
Firmware version: E113/ID76
sure just email me your makemkv drive info section like that see below
RONNIEAST
Post by RONNIEAST »
Thank you @billycar11 . Please check your email. I paid for the autoflash tool via Paypal.
crow.
Post by crow. »
Hi would like confirmation before I purchase if this drive would work to 1) burn 4K discs out of the box 2) burn after being flashed 3) not work to burn 4K discs.
Appreciate all the feedback in advance
~Crow
crow. wrote: Mon Dec 15, 2025 11:59 pm Hi would like confirmation before I purchase if this drive would work to 1) burn 4K discs out of the box 2) burn after being flashed 3) not work to burn 4K discs.
~Crow
it will rip UHD not burn
~Crow
There's no such thing as "burn 4K discs" as there are no such thing as blank 4K discs.If you are referring to BDXL, they are just blu-ray discs with more writable space.
You can rip 4K UHD discs.
itsnotme
Post by itsnotme »
very new to ripping - so please be kind and forgive my cluelessness ;-)
Got this BD-Reader from Amazon. However it can't read / open any DVD/BD with makemkv.
As soon as there's a disk inside and start makemkv, CPU goes through the roof and nothing else happens.
I suspect i might need to flash it somehow ? Can you help me? I'm on linux.
Thanks so much in advance.
OS device name: /dev/sr0
Product: BD-RE BU40N
Revision: 1.05
Serial number:
Mr_Orange
Post by Mr_Orange »
itsnotme wrote: Wed Dec 17, 2025 7:05 am Hi,
Revision: 1.05
Serial number:
You should post the full information from MakeMKV but it looks as though you have an LG BU40N which can be flashed to the 1.03MK firmware to enable Libredrive.
itsnotme
Post by itsnotme »
Hey,
that was actually all that makemkv did output in the right-hand side window.
I don't know how to get more detailed output.
Details i forget to mention..
Its a Verbatim 43890 External Slimline Mobile USB 3.2 Blu-ray READER.
I noticed in the meantime, that there's a thread for the same model as a WRITER...
Should i just post in that ?
Another thing is - i tried the sdftool to dump the current firmware, but its not able to read
anything from the drive. Some info suggests that its not possible to flash to usb-connected drives, but only drives with sata-connection ?
I am a little lost with all the conflicting info i find about the topic. Any hints on how i should proceed ? (send the drive back, get another, or is there a way with this one ?)
nicholfd
Post by nicholfd »
itsnotme wrote: Thu Dec 18, 2025 9:41 am Hey,
In general, USB drives are SATA drives with internal (to the chassis) SATA -> USB adapters. Some internal SATA -> USB adapters are "broken" - they do not pass all SATA traffic, or necessarily follow all the SATA design specs. The "archgon Premium Aluminum External USB 3.0 UHD 4K Blu-Ray Writer Super Drive" available on Amazon is known to have a defective SATA -> USB internal adapter & the drive must be removed & attached to another SATA -> USB adapter to flash. I'm sure there are others.
I've not heard this issue with any of the Verbatim external slimline drives. If it's newer firmware, it's most likely encrypted & you may need to pass the encryption option.
As a first: Post your Makemkv info. It could be a Pioneer drive inside.
whswede
Post by whswede »
is there a patched firmware around for the Pioneer UD04 to make it fully libredrive compatible?
Manufacturer: PIONEER
Product: BD-RW BDR-UD04
Revision: 1.14
Serial number: DHDL158984WL
Firmware date: 2020-06-15
Highest AACS version: 82
Drive platform: RS8A10
Firmware version: 1.14
whswede wrote: Thu Dec 18, 2025 8:16 pm is there a patched firmware around for the Pioneer UD04 to make it fully libredrive compatible?
Revision: 1.14
Should work as is
noobinitas
Post by noobinitas »
Just started ripping movies again since my physical collection has grown over the last 2 years and started adding to my server again. Not sure what has changed in the last 2 years, DVDs and Blu-Rays rip no problem but all of a sudden I can't rip any UHD movies, tried to rip movies I've already ripped and have on my server and they are also showing they are encrypted now and MakeMKV doesn't work now when it did before. I have my drive info here. Did I miss anything in the last 2 years? And also, the movies read and play in VLC no problem, just MakeMKV can't get past encryption which wasn't an issue before.
I updated the keydb.cfg file in the MakeMKV folder and that hasn't helped either. Any feedback would be appreciated as I'm sure it's something simple I'm overlooking.
Revision: 1.03
Serial number:
Firmware version: 1.03
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..07F to device 'SG:dev_21:2'
DEBUG: Code 1 at pKR,,<Y4`?)Y\ru%M^:213131686
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0BF to device 'SG:dev_21:2'
DEBUG: Code 0 at PwH=#GLZH Fj*4D?{:213130766
DEBUG: Code 2 at pKR,,<Y4`?)Y\ru%M^:213131709
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0BF to device 'SG:dev_21:2'
DEBUG: Code 2 at pKR,,<Y4`?)Y\ru%M^:213131686
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0FF to device 'SG:dev_21:2'
DEBUG: Code 3 at pKR,,<Y4`?)Y\ru%M^:213131709
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0FF to device 'SG:dev_21:2'
DEBUG: Code 3 at pKR,,<Y4`?)Y\ru%M^:213131686
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SG:dev_21:2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SG:dev_21:2'
DEBUG: Code 0 at pKR,,<Y4`?)Y\ru%M^:121264395
DEBUG: Code 4 at pKR,,<Y4`?)Y\ru%M^:213130789
Saved AACS dump file as /home/noobinitas/.MakeMKV/MKB20_v77_Swordfish_B835.tgz
DEBUG: Code 0 at &NfZVA4WMEFg;8=P:213132721
DEBUG: Code 0 at &NfZVA4WMEFg;8=P:213131341
noobinitas wrote: Fri Dec 19, 2025 7:00 am Just started ripping movies again since my physical collection has grown over the last 2 years and started adding to my server again. Not sure what has changed in the last 2 years, DVDs and Blu-Rays rip no problem but all of a sudden I can't rip any UHD movies, tried to rip movies I've already ripped and have on my server and they are also showing they are encrypted now and MakeMKV doesn't work now when it did before. I have my drive info here. Did I miss anything in the last 2 years? And also, the movies read and play in VLC no problem, just MakeMKV can't get past encryption which wasn't an issue before.
Revision: 1.03
Serial number: MZFN9590329
on linux you need bu40n 1.00 see de fw in guide
fedeb
Post by fedeb »
can someone update the post for Linux instructions?
The MKV for linux points to 1.18.2 version viewtopic.php?f=3&t=224
But this guide viewtopic.php?f=16&t=19634 tells that we must use 1.17.7 version
How we can install 1.17.7 if the only working version is 1.18.2 ?
