The last Man on Earth Season 4
The prodigy
Post by The prodigy »
Hi, when ripping any disc in this season, getting this in the logs.
Anyway I can get this to rip?
MakeMKV v1.18.2 darwin(arm64-release) started
Optical drive "DVD+R-DL HL-DT-ST DVDRW GX30N RP09d" opened in OS access mode.
Optical drive "BD-RE PIONEER BD-RW BDR-UD04 1.14 CBDL667158WLd" opened in OS access mode.
Optical drive "BD-RE PIONEER BD-RW BDR-S12JX 1.01 DDDL027031WLd" opened in OS access mode.
udf: udf_get_node: bad allocation extension size in udf_node
Calculated BUP offset for VTS #0 does not match one in IFO header.
Calculated BUP offset for VTS #3 does not match one in IFO header.
Calculated BUP offset for VTS #4 does not match one in IFO header.
Calculated BUP offset for VTS #5 does not match one in IFO header.
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_06_1.VOB' at offset '0'
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading 'DVD+R-DL HL-DT-ST DVDRW GX30N RP09' at offset '0'
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_07_1.VOB' at offset '0'
Signature is invalid in IFO file
Calculated BUP offset for VTS #8 does not match one in IFO header.
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading 'DVD+R-DL HL-DT-ST DVDRW GX30N RP09' at offset '1151539200'
Re: The last Man on Earth Season 4
Errors like that mean the optical drive could not correctly read data from that spot on the disc. The standard advice is to gently clean the disc and try again.
gkar_of_narn
Post by gkar_of_narn »
Thanks prodigy for introducing me to The Last Man on Earth series....I just ordered it on "A"
