"Failed to Open Disc" on every BD (and Unencrypted ISO)
krizzz
Post by krizzz »
I must be missing something big here because I can't get MakeMKV to open anything.
  • Multiple different New and Old BD's
  • Multiple ISO Images ripped with encryption removal via AnyDVDHD
I disabled AnyDVD due to the warnings that MakeMKV throws when I try starting it while it is running.
Here is the output when I try to open either an encrypted disc or an unencrypted ISO:
MakeMKV v1.7.2 win(x64-release) started
This disc uses newer version of AACS protection. Please let us know about it by visiting http://www.makemkv.com/a/?hoaGhoadiknSy2...
Also, I'm running Win7 64-bit and the app was both installed with Admin privileges and also executes with Admin privileges.
Thanks for ANY ideas!!
Re: "Failed to Open Disc" on every BD (and Unencrypted ISO)
Post by mike admin »
Please post a log when you open unencrypted ISO.
krizzz
Post by krizzz »
OK, this is REALLY weird. I went into the settings to try and find/enable logging so I could post per your request. I checked the "Enable Debug" box and restarted the app. I am running it right now against an ISO and it seems to be working now...hmmmm. I'll do some additional testing (and try with a standard encrypted BD) and report back.
krizzz
Post by krizzz »
Encrypted discs are still failing. Here is a debug from the "Memento" BD:
Debug log started at Mon Mar 05 19:17:06 2012 , written by MakeMKV v1.7.2 win(x64-release)
001005:0000 MakeMKV v1.7.2 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Administrator/MakeMKV_log.txt
003310:0000 This disc uses newer version of AACS protection. Please let us know about it by visiting http://www.makemkv.com/a/?AgICAgKah25UY ... B2fSGnYA==
003303:0000 The volume key is unknown for this disc - video can't be decrypted
001003:0020 DEBUG: Code 0 at F|7?_re59FVQqCz :121263544
001003:0020 DEBUG: Code 0 at F|7?_re59FVQqCz :29396897
001003:0020 DEBUG: Code 233 at J+diquTZKicgMso47+3EjMM+:0
001003:0020 DEBUG: Code 233 at KVoPQwaIgHOyO6MOsw+r+i/S:0
001003:0020 DEBUG: Code 233 at XsoLdU8smr3T5hp/q/BHVRHm:0
001003:0020 DEBUG: Code 233 at mq4z6m70xRRWyoQiT38hEvRa:0
001003:0020 DEBUG: Code 233 at y7U+ZE0XNeqfnSehI8wALIai:0
001003:0020 DEBUG: Code 233 at tP8CFdORmcbj592nak/5kmdu:0
001003:0020 DEBUG: Code 233 at fww5jHZklaEHWdMvN49gMQlo:0
001003:0020 DEBUG: Code 233 at mkY9TbRkp3PjMJV9z4YdzC4i:0
001003:0020 DEBUG: Code 233 at cHAFq25DqCiyeQaann7Rhx4z:0
001003:0020 DEBUG: Code 233 at Ehw0yCjENCB6uVSXdPk5rzrY:0
001003:0020 DEBUG: Code 233 at k4O5qeL6MBC9EIJHLLu9q3F5:0
001003:0020 DEBUG: Code 233 at uiVtESA8Quw6VrCGsJoVMZoZ:0
001003:0020 DEBUG: Code 233 at vyBUcqCDhvY94YNWfjvZah+j:0
001003:0020 DEBUG: Code 233 at WrF+o7ez7cInEcC85Gcuiu0C:0
001003:0020 DEBUG: Code 233 at s6ZLDyYEExvsRvo8iJQDZJWi:0
001003:0020 DEBUG: Code 233 at XBqPhpvI4EMoCAjf66lwPcfS:0
001003:0020 DEBUG: Code 233 at uwqSlU6t6CL8GLaMYKVPpfWn:0
001003:0020 DEBUG: Code 233 at OxrZ9FWLTCL4/JXpnXjOuG6R:0
001003:0020 DEBUG: Code 233 at EVJ4F0l9eDo0/H60U6c1J1gv:0
001003:0020 DEBUG: Code 233 at WGU73QNPVfKucPfsFsXoQFsq:0
001003:0020 DEBUG: Code 233 at /6qmAg7jcGfKkEK0fjqUPvFJ:0
001003:0020 DEBUG: Code 233 at B4XbCWWRH1Dskq7Nqq2h5mIU:0
001003:0020 DEBUG: Code 233 at f8LU4JF0+PZ5xlZV4rJh8u62:0
001003:0020 DEBUG: Code 233 at sJZf3N48jKPTZ/dcErkRk26q:0
001003:0020 DEBUG: Code 233 at cwMvVdgvAJOLhUXZU5/ICass:0
001003:0020 DEBUG: Code 233 at uqw0C6uqawF3gbj4E72vrREG:0
001003:0020 DEBUG: Code 233 at j4N023aI9SI4Ry/vlfjzTvkL:0
001003:0020 DEBUG: Code 233 at Qt2sdVhMDGvCUGJPPWS6yxqR:0
001003:0020 DEBUG: Code 233 at Nn95jKvbgz6QJHgDnlNaR52k:0
001003:0020 DEBUG: Code 233 at UEE/RhVlIeWD0Gt3VgSQNUUk:0
001003:0020 DEBUG: Code 233 at IpMGPx45I9Ni/UrbAc7huzyq:0
001003:0020 DEBUG: Code 233 at GmWviSy24ZG+AGq9xk/jvDbT:0
001003:0020 DEBUG: Code 233 at 0krNufrhiRqJYvE5/S/xQyir:0
001003:0020 DEBUG: Code 233 at xBGYaMh3ku4AI2rw++GCuwxm:0
001003:0020 DEBUG: Code 233 at jidsGi3Kxchn+mp0ySE756Pt:0
001003:0020 DEBUG: Code 233 at URdi+2bVMAcLSXNS2KrvdjfC:0
001003:0020 DEBUG: Code 233 at 6mkaK0yztRcjB59Tqodzaaba:0
001003:0020 DEBUG: Code 233 at mYeG1gF9pYSQfJ59OCeAVpj6:0
001003:0020 DEBUG: Code 233 at kWzkwjIB8y41AnUbbssnfaNt:0
001003:0020 DEBUG: Code 233 at oLvOhEoPcKVeWNRjWVLzquq0:0
001003:0020 DEBUG: Code 233 at 8EMBCE7rOi9XBJF9V5Hirb6o:0
001003:0020 DEBUG: Code 233 at SNDbTeVF66wYPcySZtPTHa2V:0
001003:0020 DEBUG: Code 233 at 9GoVXXqpmT6gtZl1oGM5K47D:0
001003:0020 DEBUG: Code 233 at EduDv+dgEd7KjF0JYoC9lPa7:0
001003:0020 DEBUG: Code 233 at Wrx8KuuP15lflnbbfEr2J7Ez:0
001003:0020 DEBUG: Code 233 at v/+y7hN+r7c/u5HQ09y9eKyB:0
001003:0020 DEBUG: Code 233 at vGrUlteKbvN5eMdzR0LmI2vg:0
001003:0020 DEBUG: Code 233 at nQlAKzWUcA0z3I5sK32ifaid:0
001003:0020 DEBUG: Code 233 at hyzUMjCoHqvgpxREKi6eyreE:0
001003:0020 DEBUG: Code 233 at VLx5tyGz2ACurKAgzfyyA3UP:0
001003:0020 DEBUG: Code 233 at +dI8Chj5D+5DotBnnLto3uEr:0
001003:0020 DEBUG: Code 233 at 1kgwryguQ2QNSiPiv2LKcf5m:0
001003:0020 DEBUG: Code 233 at 3Gbp7sPRUxj6NS3mVCnYkB+3:0
001003:0020 DEBUG: Code 233 at osKePUkGrk7hn2YfEFdImevE:0
001003:0020 DEBUG: Code 233 at Gx5plN/IbhPk2epvE+S8FMTW:0
001003:0020 DEBUG: Code 233 at ZpGg76TpvRDTjrEBiNEBrMJ4:0
001003:0020 DEBUG: Code 233 at N8vLPuHJlBt1COy28rdV2tYC:0
001003:0020 DEBUG: Code 233 at oHoSj2J3YmbTqbDJPqPuxMIN:0
001003:0020 DEBUG: Code 233 at 2RkZZ2s46jTL33mw8UCRm7Ih:0
001003:0020 DEBUG: Code 233 at dMvEAQNt9Z/KYw99JZK6RXem:0
001003:0020 DEBUG: Code 233 at iV3mdrmXJ6CR1owxjJlraTDK:0
001003:0020 DEBUG: Code 233 at xNE81WIeP/HoFnRkRNU+E6bP:0
001003:0020 DEBUG: Code 233 at 133dyuRnVFiEVa0/zJ9ibTMa:0
001003:0020 DEBUG: Code 233 at UvqBGoc8ckw17EjJKv4VgdXG:0
001003:0020 DEBUG: Code 233 at xtOatILTN2rDtti5tJY4cUQA:0
001003:0020 DEBUG: Code 233 at 9z4r6jqFpuXrVacwHQDGzc27:0
001003:0020 DEBUG: Code 233 at bSl+Gq0gOxg6lVrhR7jfSMAJ:0
001003:0020 DEBUG: Code 233 at XxMDMQDy0SnxhLKLMbRbUF/h:0
001003:0020 DEBUG: Code 233 at j813QyuU5CtR+Y9/IKSM+6RZ:0
001003:0020 DEBUG: Code 233 at VoQxx8S+O9zPDOLjj5Amw5I6:0
001003:0020 DEBUG: Code 233 at hGwHl/+RBakDfVXHH031KXv9:0
001003:0020 DEBUG: Code 233 at 33Cp1KTz/b/NBMxe52R+wnuD:0
001003:0020 DEBUG: Code 233 at f9tzgjKSERavRHgiXH7j2U1J:0
Application exited at Mon Mar 05 19:22:55 2012
Here is a debug from the "Kick Ass" BD:
Debug log started at Mon Mar 05 19:13:26 2012 , written by MakeMKV v1.7.2 win(x64-release)
003310:0000 This disc uses newer version of AACS protection. Please let us know about it by visiting http://www.makemkv.com/a/?AgICAgKah25UZ ... ElghxkAJA=
001003:0020 DEBUG: Code 233 at VdelVVYhVig30sn/PIPpOgP2:0
001003:0020 DEBUG: Code 233 at uuw3JgwrINUZ7DQFDOhkabbH:0
001003:0020 DEBUG: Code 233 at CeAO2W7zyMroR7Z2ekFHOWcT:0
001003:0020 DEBUG: Code 233 at 3Qf4dywYxhJv50K/g9oumPEf:0
001003:0020 DEBUG: Code 233 at dR1lli3yCX1AVbosQoF4dljv:0
001003:0020 DEBUG: Code 233 at jFQZZJwHDD9UVIUv8QCVKBBT:0
001003:0020 DEBUG: Code 233 at 7hdKsgOXWYVrKkatg6HJi+2A:0
001003:0020 DEBUG: Code 233 at wfNR+W+AHz6ifwZZhjXtkq5z:0
001003:0020 DEBUG: Code 233 at xDY+FlI48TywY5C1u2+ZAJYO:0
001003:0020 DEBUG: Code 233 at AQ7sWGr/gzTClpX19ej6EGvx:0
001003:0020 DEBUG: Code 233 at PNOlfmNt9rNBMDLwsfNO+V++:0
001003:0020 DEBUG: Code 233 at e3RtUAHkL21s1m15uc8gHXqQ:0
001003:0020 DEBUG: Code 233 at r6SPiYbqNig44ajb2tLUWClO:0
Application exited at Mon Mar 05 19:16:31 2012
Do you use the program in evaluation mode, or with current beta key, or with purchased key?
krizzz
Post by krizzz »
Not sure if it's the beta key or an eval key, but not a purchased one.
Z0001
Post by Z0001 »
Hi
Was there a solution to this problem as I am getting similar failure messages with encrypted AnyDVD ripped iso Blu ray files (whether AnyDVD is on or off). I am using a beta key. I have posted a similar thread as older ones not Progressed since March.
Thanks v much
Z
Z0001
Post by Z0001 »
OK, I have tried this again and still no luck, I used to be able to load and convert Blu rays but something has changed I am on version 1.7.4 with the current Key.
This is the error message I get with every Blu ray when I use the makemkv load file facility:
MakeMKV v1.7.4 win(x64-release) started
and this is the error message I get when mounting the iso using Virtual CloneDrive and AnyDVD enabled:
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0566B2FFD3262E6984D42B799A7DCFF877D to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0E715C256FFEA8321E767EAB61ED69B121D to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0B10F13A6A3E1954248D3BB6F10314AB9C5 to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..004043071E5A68794580B560639E07F4730 to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..02EE9A55CB63B97C16E5C7EC6B341FF0618 to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..09EC9749D07C010FE5DC0462AE047C6F16D to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0FF3F70E14C0915AB43487D1181C73EF745 to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0BE6BBD26A9F162F041F11800CE38E9AB71 to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..097E8F489B16DFE8580707CA0F099FA1824 to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0AAB0073B5CDDCA063BDCE033AE251FFA1F to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0457957570CBC9C4708366CAE1C389A6D32 to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0EED39DD7326F1339CED2F4B4C90E5A8F9A to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0BE6C995E0344DD8CEB8C48A686F1E1FBBE to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..05E63B949F28C96ABAA612AA8359335BEB0 to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..00F0DA8DBB81802BDD68D2ACF292F3068C1 to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..00DAD3F13764D3657A8CADEDBA0E0D47997 to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0686D3E2164D2DAD1AE1FB51FBA13F7C49F to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..016DB69F1AA1C871A533C9509A797433625 to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..05DFBBBD8FC26ECDC98C2E4C2B4FB76E179 to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0852C2FA078EEB783EDCCA56F9F718BA44B to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0DA542947A0F5C5D59F32D87E14F30ABEEF to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0C9B7B0B33CD4A01DA8D4F93C32FC2F8A13 to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..00BF2AECDFF712A16DA34071A243DA08B21 to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..06F5EC9C2C344601B85D064A032F4C6D240 to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..00718706146DCA2FEDE2CF8BBE0060F22D4 to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0FAF3792190BB1095AFE0D92B5D822618D7 to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..04AF8E5EC28C9C37840984533A5A9481A5E to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..037046D29B77ADFE3E4E06CE98CFA38E00F to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0E0E6FB90318660721AAE204C69AB8A408D to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..047AD71F0B0D0C846B69C42245BCC701D to device 'SPTI:\Device\CdRom1'
I have tried loading the mounted iso with AnyDVD disabled but the decryption just seems to stall and the remaining time shown just keeps going up.
Any ideas why all of a sudden I cant load and convert Blu rays?
Z
