ArifHubble23
Re: SDFtool Flasher
Post by ArifHubble23 »
Many thanks! :D
Jnyfive
Re: SDFtool Flasher
Post by Jnyfive »
ckmccollim wrote: Fri Nov 07, 2025 2:21 am I wanted to create a written document that I could follow in the future for flashing the firmware for LG BP50NB40 SVC:NB52. (I really like this drive and may purchase another one.)
I followed the animated GIF video information for details.
I later saw another fellow on Youtube (https://www.youtube.com/watch?v=R2oIsrTIShI) flashed his final version to “DE_LG_BU40N_1.03_MK.bin”
Should I be on “DE_LG_BU40N_1.03_MK.bin” or “DE_LG_BU40N_1.00.bin”?
(If I should be on the first, what is the best way to get there from the second?)
Thank you for your help!
SDFtool Flasher for LG BP50NB40 SVC:NB52
viewtopic.php?f=16&t=22896
11-1-2025
To Update this LG BP50NB40 (NB52) Slim Portable Optical Drive to be able to read Ultra HD Blu-ray 4K discs follow these instructions and video. (I converted the animated GIF to a MP4 video file for easier viewing so I could start and stop it.)
Go to the link above and download both the current "SDFtool Flasher" and "All You Need Firmware Pack". Once both are unzipped and the Flasher tool running:
"UPDATE - 21/12/2021:
The latest version of the SDFtool Flasher has a checkbox option to flash the boot loader with the main firmware to the drive, although, currently there's really no need to use it.
For the moment, to flash the BP50NB40 SVC:NB52, using the latest SDFtool Flasher, follow the steps below:
1. Flash the drive to BP50NB40 (NB50) 1.03-MK."
MY INTERPRETATION OF ABOVE:
Run the SDFtool Flasher tool.
Select the drive to be flashed from the top "Please select a Drive" pulldown box.
It will look something like this
(but with your drive letter and serial number):
H: HL-DT-ST_BD-RE_BP50NB40_1.03_212107081603_SIK04NAG90606
Then select the firmware to be flashed from the bottom "Please select a Firmware to Write" pulldown box:
DE_LG_BP50NB40-NB50_1.03_MK.bin
The "MT1959 Platform:" has a Green Checkmark.
The "Encrypted Firmware:" has a Green Checkmark.
The "Include boot loader?" Is NOT checked (and I didn't check it.)
"WRITE Firmware" Blue circle selected.
Click "START" button and wait till it is completely finished.
(Onscreen information will keep you informed the whole time of the progress and the success.) When it is completely finished the SDFtool Flasher tool will reset itself with no drive or firmware selected.
"Now for the crossflash:
2. Select the RECOVERY option and in the pop up, select the BP50NB40 (NB50) 1.03-MK firmware that you just flashed.
3. Select the BP60NB10 1.00-MK or BU40N 1.00 firmware in the normal drop box.
4. Click START"
MY INTERPRETATION OF ABOVE CROSSFLASH:
Select the optical drive again in the top box:
H: HL-DT-ST_BD-RE_BP50NB40_1.03_212005070917_SIK04NAG90606
Click on the "RECOVER Drive" option, and a popup window will open up. The top of this purple colored box will say "Select the drive's currently installed (wrong) firmware file..."
You will select "DE_LG_BP50NB40-NB50_1.03_MK.bin" and click on "Open" button.
Now click on the bottom "Please select a Firmware to Write" pulldown box. (It will say at the top of this purple box "Select a firmware file to write...")
Select "DE_LG_BU40N_1.00.bin" and click "Open" button.
Verify the following:
The "Encrypted Firmware:" has Red X.
"RECOVER Drive" Blue circle selected.
(Onscreen information will keep you informed the whole time of the progress and the success.) When it is completely finished the SDFtool Flasher tool will reset itself with no drive or firmware selected. You can now click "EXIT" button to finish.
10-29-2025 Purchased from Best Buy.
LG - 8x External USB 2.0 Blu-ray Disc Double-Layer DVD±RW/CD-RW Disc Rewriter - Black
Model: BP50NB40 SKU: 9243009
Purchase Date: Oct 29, 2025
Total: $112.86
Key features:
External - Connects VIA USB 2.0.
Silent Play Reduces Noise from Disc Spin During Movie Playback.
Supports BDXL (100GB Triple Layer) Disc.
Jamless Play Smooths Out Playback of Damaged Blu-ray or DVD Discs.
Max. 6X BD-R Read and Write Capability / Max. 8X DVD±R Write Speed.
BEFORE FIRMWARE UPDATED
OS device name: H:
Product: BD-RE BP50NB40
Revision: 1.03
Serial number: xxxxxxxxxxxxxx
Firmware date: 2121-07-08 16:03
Highest AACS version: 72
Harware support: Yes
Firmware support: No
Firmware version: 1.03
AFTER FIRMWARE UPDATED
OS device name: E:
Product: BD-RE BU40N
Revision: 1.00
Serial number: xxxxxxxxxxxxxxx
Firmware date: 2116-12-20 15:28
Firmware version: 1.00
Disc Information
Label: THE_GREATEST_SHOWMAN
Timestamp: 2018-02-26 13:05:17
Protection: AACS2.0/C v61
Data capacity: 58.52 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
Hi, I followed the steps but I only see DE_LG_BP50NB40-NB50_1.01_MK_HBD and DE_LG_BP60NB10_1.00_MK_HBD from the Hybrid Firmware for BP50NB40 zip file. I do not see the 1.03_MK file. I found the "alll you need firmware pack" and HL-DT-ST-BD-RE_BP50NB40-NB50-1.03-NM00800-212005070917 is there but no 1.03_MK. Which is to be used? My drive is manufactured 10/2025 and came with a 1.03 firmware.
Re: SDFtool Flasher
Jnyfive wrote: Sat Dec 13, 2025 4:26 pm
11-1-2025
4. Click START"
Total: $112.86
Key features:
OS device name: H:
Revision: 1.03
OS device name: E:
Revision: 1.00
Disc Information
Number of layers: 2
No, don't use those old HBD firmwares I made years ago.
HL-DT-ST-BD-RE_BP50NB40-NB50-1.03-NM00800-212005070917 is 1.03-MK. It's much easier to say MK than NM008........
Just get the firmware pack from the first post of the SDFtool Flasher thread.
merlinthesage
Re: SDFtool Flasher
Post by merlinthesage »
Hi, I also purchased 2 Verbatim Slimline drives
Looking at the drives on MKV it looks like both are encrypted and I have tried to use the DE_LG_BU40N_1.03_MK.bin but both say that it isn't a MT1959 Platform, but MKV says they are. I will post both drive info
OS device name: J:
Revision: 1.02
Serial number:
Bus encryption flags: 1F
Firmware version: 1.02
OS device name: K:
Revision: 1.05
Serial number:
I know I am new to the forum and this could be a stupid question, but Why won't this work? and how do I go about making it work? Thanks
zittrig
Re: SDFtool Flasher
Post by zittrig »
There are no Not-MT1959-plattforms with the BU40N available.
Checked it with another cable oder with another USB port? Also you can try to extract the drive carefully and try an USB to Mini-SATA adapter for the flashing process.
merlinthesage
Re: SDFtool Flasher
So looking at it. On my desktop with other cables and all it still does that. But just got on my laptop and it worked fine. And now it is patched. Makes me wonder what on my desktop was messing with it.
nicholfd
Re: SDFtool Flasher
Post by nicholfd »
merlinthesage wrote: Thu Dec 18, 2025 8:48 pm So looking at it. On my desktop with other cables and all it still does that. But just got on my laptop and it worked fine. And now it is patched. Makes me wonder what on my desktop was messing with it.
Do you possibly have an another/internal drive on your desktop & maybe were not selecting the correct drive?
XrayDoc88
Re: SDFtool Flasher
Post by XrayDoc88 »
I have a LG WH16NS40 previously flashed to read UHD discs that has stopped showing up in Windows 11 File Explorer. It is still present in the BIOS and has an error listed in Device Manager. My suspicion is that the firmware may have got corrupted when my computer froze while ripping. Is there any way to flash the firmware again when it doesn't have a drive letter in File Explorer? I downloaded the SDFtool Flasher and it doesn't see the drive.
Re: SDFtool Flasher
Post by d00zah »
XrayDoc88 wrote: Sat Dec 20, 2025 10:01 pm I have a LG WH16NS40 previously flashed to read UHD discs that has stopped showing up in Windows 11 File Explorer. It is still present in the BIOS and has an error listed in Device Manager. My suspicion is that the firmware may have got corrupted when my computer froze while ripping. Is there any way to flash the firmware again when it doesn't have a drive letter in File Explorer? I downloaded the SDFtool Flasher and it doesn't see the drive.
Try... remove power from the drive. If internal, power down the PC for a few second & restart. Sometimes things get confused.
MIGHT also be worthwhile to delete the failed device from DM & let Windows re-detect on next boot (or, 'scan for hardware changes')..
XrayDoc88
Re: SDFtool Flasher
Post by XrayDoc88 »
Thanks, but I've already done both of those suggestions and it is still hosed. :(
XrayDoc88
Re: SDFtool Flasher
Post by XrayDoc88 »
I don't know if this information will be useful to someone else in the future, but I stand corrected with my previous statement. I had already uninstalled my LG drive in Device Manager more than once and rebooted. Each time, the same error was listed in Device Manager and the drive did not show up in File Explorer. This last time I tried the same uninstall, but then shut down the computer for about 2 minutes. When I manually turned the computer back on, everything was fixed! I've always treated rebooting as the same thing as shutting off and turning back on. But apparently they are slightly different. I guess a reboot keeps power to the motherboard, where a shut down completely removes power. Whatever had corrupted my LG drive was fixed by simply completely removing power and starting up again! :D
Thanks d00zah!
Re: SDFtool Flasher
Post by d00zah »
In the realm of electronics, a power cycle can often be downright magical. :) Glad you got it sorted.
kaysee
Re: SDFtool Flasher
Post by kaysee »
Is there a list of which LG and ASUS desktop drives can have their firmware cross-flashed to each other? A typical scenario is when considering a given LG model and whether it could be cross-flashed with ASUS firmware to disable jamless playback.
Re: SDFtool Flasher
kaysee wrote: Mon Dec 22, 2025 9:59 pm Is there a list of which LG and ASUS desktop drives can have their firmware cross-flashed to each other? A typical scenario is when considering a given LG model and whether it could be cross-flashed with ASUS firmware to disable jamless playback.
No list. MT1959 drives can all be crossflashed as long you flash full size to full size and slim to slim and never vice versa! So each full size can be flashed to ASUS full size, NS60 or NS58 to do disc quality scans.
kaysee
Re: SDFtool Flasher
Post by kaysee »
What platform would be expected for an LG UH12NS30 manufactured 12/2015? This is based on the label without MakeMKV information.
