AACS v82 Blu-ray dump (Disc AVXK, JP)
ckdals103
#1 Post by ckdals103 » Sat Dec 13, 2025 1:06 pm
I am unable to decrypt this Blu-ray disc with the current MakeMKV version.
MakeMKV reports that this disc uses a newer version of AACS (v82).
I have attached the AACS dump file generated by MakeMKV.
Disc information:
- Format: Blu-ray
- Region: Japan
- Type: Live concert Blu-ray
- Disc ID: AVXK
- AACS version: v82
MakeMKV version:
- v1.18.2 (Windows x64)
Thank you.
Re: AACS v82 Blu-ray dump (Disc AVXK, JP)
#2 Post by dcoke22 » Sat Dec 13, 2025 5:01 pm
You should email those dumps to svq@makemkv.com so a key can be created for MakeMKV's built in hashed key mechanism. A few days after emailing the dump, try the disc again and if a key is available, MakeMKV will download it automatically in the background.
There is a separate second decryption mechanism that MakeMKV supports, the public KeyDB. To contribute to the public KeyDB, use the template and follow the instructions in the first post in the Public KeyDB Disc Submissions thread. Instructions for downloading the keyDB and using with MakeMKV are also in that thread.
