Create blu ray menus?
HelloFromMe
Post by HelloFromMe » Sat Dec 13, 2025 4:51 am
Hi, MakeMKV has worked great for me for many years so I hope this topic is in the right section of the forum.
I want to try burning 3 Blu-ray-compatible files (no protection) on one 25 GB disc with a menu.
They can be very simple menus, as all I need is the option to choose the files for playback on a standalone bluray player.
Any suggestions for a free(ish) and easy-to-use software?
Thanks in advance.
flojo
Re: Create blu ray menus?
Post by flojo » Sat Dec 13, 2025 6:00 am
There's a couple on this page, I never used them, but "TMPGEnc Authoring Works" or "multiAVCHD" looks good enough.
https://www.videohelp.com/software/sect ... converters
Post by dcoke22 » Sat Dec 13, 2025 5:15 pm
On a Mac, Roxio Toast Pro can author a blu-ray disc. On Windows, Nero Burning Rom should be able to author a blu-ray.
Do you really need to burn a disc? Many blu-ray players can play a file from a USB flash drive. Lots of TVs can too.
