absolutelydisgusting
#1231
Post
by absolutelydisgusting » Fri Dec 12, 2025 7:11 pm
If anyone was having trouble with the BDR-XD08 and getting an error like
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom1'
consider using the USB-A cable that came with the drive instead of a USB-C or Thunderbolt cable no matter what the rating is lmao.
#1232
Post
by Billycar11 » Fri Dec 12, 2025 8:38 pm
absolutelydisgusting wrote: Fri Dec 12, 2025 7:11 pm
That has nothing to do with that
Its either your sdf was not yet updated yet and the drive required a reboot and unplugging the cable and using the other one did that or you had a power issue
Nothing to do with the drive cable
eo10998
#1233
Post
by eo10998 » Mon Dec 15, 2025 12:38 am
Billy,
Recently bought a XD08B from you, so far unable to rip anything.
Getting Scsi error - illegal request: cannot write medium, which maybe a power issue? I'm trying different cables/power sources in the meantime
I noticed Makemkv is saying drive firmware date is 2024-10-09, and Libre drive possible but not enabled. I thought firmware date should be much earlier than that? I've not updated firmware to my knowledge, just plugged in and tried ripping.
Sorry, new to this but trying to research as well.
nicholfd
#1234
Post
by nicholfd » Mon Dec 15, 2025 1:25 am
eo10998 wrote: Mon Dec 15, 2025 12:38 am
Billy,
Did you try using the cable that came with the drive & connecting all the USB connections? Most slim-line drives require 2 x USB connections to the computer for data & extra power. make sure the "Y" cable has all 3 x ends connected.
If the drive you purchased came with an AC adapter for power, make sure you are using that adapter *and* the supplied USB cable.
Thanks,
Frank
#1235
Post
by Billycar11 » Mon Dec 15, 2025 1:50 am
Billy,
you have a sdf download issue all drives are fully tested before shipping 100% works i can manually give you the sdf and HK if you email me
eo10998
#1236
Post
by eo10998 » Mon Dec 15, 2025 6:41 am
Billycar11 wrote: Mon Dec 15, 2025 1:50 am
Billy,
Believe this did the trick! Thank you!!
Oscycadena
#1237
Post
by Oscycadena » Wed Dec 17, 2025 5:23 am
I was wondering, if I set up MakeMKV to play BDs on VLC, will that ruin my drive from ripping?
Thank you for the drive, it’s got my plex set up fully going!
#1238
Post
by Billycar11 » Wed Dec 17, 2025 6:32 am
Oscycadena wrote: Wed Dec 17, 2025 5:23 am
no it wont ruin it
will continue to rip just fine
tober4
#1239
Post
by tober4 » Thu Dec 18, 2025 7:43 am
Hello, Billycar11.
I have emailed you about purchasing a drive from you, but I have a question about payment that I didn't want to email you about because I didn't want to start a new chain, as per the 2nd step in the order process. I also messaged you on Reddit, but something borked, so I registered here instead.
I wanted to use the PayPal option of paying with my credit card without creating a PayPal account, which I don't currently have. Is this okay, or do I need to make a PayPal account? If it's absolutely necessary, then I will make an account with PayPal.
#1240
Post
by Billycar11 » Thu Dec 18, 2025 2:03 pm
tober4 wrote: Thu Dec 18, 2025 7:43 am
Hello, Billycar11.
I answered you about this on Reddit already and email would have been the appropriate place in the same chain.
But yes that's why guest checkout is there with the pay with credit or debit card option
I see no reason why you not think it's ok it a payment option in my PayPal store it's all fine
mzajda
#1241
Post
by mzajda » Thu Dec 18, 2025 3:35 pm
Good morning Billy, I just sent you an email with a request to purchase a BDR-XD08B. Looking forward to making the transaction. Thanks again for your service!
tober4
#1242
Post
by tober4 » Thu Dec 18, 2025 3:36 pm
Billycar11 wrote: Thu Dec 18, 2025 2:03 pm
Hello, Billycar11.
Hello Billycar11,
For some reason, I wasn't getting your message on Reddit. I wasn't sure if having a PayPal account was a requirement to purchase a drive from you. I didn't want to eff up the 6th step, so I made a PayPal account, just in case, and then made the order. Hope everything went okay.
FrickDude
#1243
Post
by FrickDude » Sat Dec 20, 2025 7:39 pm
Billycar11 wrote: Wed Nov 19, 2025 11:03 pm
FrickDude wrote: Wed Nov 19, 2025 7:43 pm
Billycar11 wrote: Tue Nov 18, 2025 3:14 am
it not the actual drive model i send you an xd08 the fw is from an xd08u makemkv now supports all UHD pioneers even on the latest fw
What do you mean MakeMKV now supports all UHD Pioneers even on latest FW? Like if I find any Pioneer UHD drive on FB Marketplace I can purchase that and have you flash it? Looks like remote flashing is $25. Or would it need to be sent to you?
How do these XD08's compare to the other models you don't have in stock? Are these XD08's somehow not as ideal or not as good in any way when ripping compared to the BDR-S13U's or BDR-X13U's? I'm new to all this sorry and I just want to buy once and not buy a lesser version then realize I should have purchased a better one like mentioned in the last sentence but I don't know if they are actually better when it comes to ripping or just more premium quality physical product? Thank you.
Exactly what I said makemkv supports all UHD pioneers out of the box for UHD ripping.
But non uhd pioneers are still not cross flashable to UHD after 12/22 unless purchased from a flasher.
Remote flashing is still not possible after 12/22 fw too
Ordered a Pioneer BDR-XD08B from @Billycar11 and received quickly. Worked right out the box using MakeMKV to rip my first couple 4k drives I borrowed from a friend to verify functionality. Didn't have to do anything myself to make it work. Thanks @Billycar11 for putting this out there for us.
arlo48
#1244
Post
by arlo48 » Sun Dec 21, 2025 3:57 am
I'm planning on ordering Pioneer BDR-XD08B, but is that drive compatible with bluray as well as UHD disks? Are there limitations with it that is good to know before ordering? Thank you in advance!
#1245
Post
by MartyMcNuts » Sun Dec 21, 2025 8:35 pm
arlo48 wrote: Sun Dec 21, 2025 3:57 am
Works with CD/DVD/BD/UHD discs.
