LibreDrive for Pioneer drives
paul.t
Post by paul.t »
Hello! I'm new to this LibreDrive for Pioneer drive train.
Recently bought a Pioneer sourced from Japan
Wonder will LibreDrive works on this drive?
OS device name: F:
Manufacturer: PIONEER
Product: BD-RW BDR-212M
Revision: 1.00
Serial number: TCDL002844WL
Firmware date: 2019-01-10
Highest AACS version: 82
Firmware version: ID20
Many thanks!
paul.t wrote: Fri Dec 12, 2025 1:51 pm Hello! I'm new to this LibreDrive for Pioneer drive train.
OS device name: F:
Revision: 1.00
Many thanks!
PM sent.
alx89
Post by alx89 »
MartyMcNuts wrote: Tue Dec 09, 2025 11:10 pm
alx89 wrote: Tue Dec 09, 2025 11:07 pm I have MakeMKV 1.17.7. Do I need to update it?
No. Just insert a UHD disc and start ripping!
When I try to rip, I get this message:
Any ideas are most welcome!
alx89 wrote: Fri Dec 12, 2025 6:35 pm
Internet access must be enabled for Makemkv.
kzburner
Post by kzburner »
Is it possible to update the firmware of this drive to read UHD discs now?
Product: BD-RW BDR-XD08U
Revision: 1.02
Serial number: CGDL002140UC
Firmware date: 2022-12-27
Drive platform: Pioneer RS9331
Firmware version: ID05
should work as is
you likely have a download issue with makemkv
juli1_19_
Post by juli1_19_ »
Hello everyone,
Also have some problems with my pioneer drive. Here are the specs :
Informations lecteur
Nom du lecteur SE : E:
Fabricant : PIONEER
Produit : BD-RW BDR-XD07U
Révision : 1.06
Numéro de série : BADL003704WL
Date micrologiciel : 2024-10-09
Marqueurs d'encryptage bus : 13
Drive platform: Pioneer RS8D31
kzburner
Post by kzburner »
Billycar11 wrote: Sun Dec 14, 2025 5:16 am should work as is
Thanks, yep sorted it out!
bhenry001
Post by bhenry001 »
I have a Pioneer BD-RW BDR-12D, it says it is ready, but when I put in a UHD disc, say Wizard of Oz, it say Disc not found.
OS device name: E:
Product: BD-RW BDR-212D
Revision: 1.02
Serial number: DGDL056325WL
Firmware date: 2022-03-16
Bus encryption flags: 13
Highest AACS version: 50
Drive platform: RS8F00
Firmware version: 1.02/ID61
When I looked at other posts, it just said PM sent. Not sure what that means. Please help.
Thank you,
Bruce
bhenry001 wrote: Mon Dec 15, 2025 12:20 am I have a Pioneer BD-RW BDR-12D, it says it is ready, but when I put in a UHD disc, say Wizard of Oz, it say Disc not found.
OS device name: E:
Revision: 1.02
Thank you,
Bruce
Of course not! It is not a UHD model!! Libredrive does not equal UHD readability. It can be cross-flashed though. Just email Billycar11 your MakeMKV drive info and libredrive info sections above for assistance.
waluigi4smash2018
Post by waluigi4smash2018 »
Hi there! My drive isn't listed in the newest SDF.bin. Can mine be added? Thanks!
Product: BD-RW BDR-212BK
Revision: 1.04
Serial number: DCDL048915WL
Firmware date: 2022-12-20
Firmware version: ID81
waluigi4smash2018 wrote: Mon Dec 15, 2025 4:24 am Hi there! My drive isn't listed in the newest SDF.bin. Can mine be added? Thanks!
Revision: 1.04
Did MakeMKV create a firmware dump file in MakeMKV's data directory (listed on the General tab of preferences)? If so, email it in.
OS device name: E:
Revision: 1.02
Thank you,
Bruce
PM sent.
waluigi4smash2018
dcoke22 wrote: Mon Dec 15, 2025 5:31 am
Revision: 1.04
You’re right, it looks like it created a dump and I didn’t notice. I just emailed the .tgz file to support@makemkv.com. Thanks for your help.
warpgremlin
Post by warpgremlin »
warpgremlin wrote: Sat Jun 07, 2025 7:27 pm Have Pioneer drive (SATA native, via USB enclosure to a Windows box).
UHD disks won't decrypt. Need firmware update... I think.
Product: BD-RW BDR-S13JX
Revision: 1.04
Serial number: xxxxxxxxxxxx
Firmware date: 2022-12-12
Highest AACS version: 61
Firmware version: ID72
Giving this a bump. Is this a supported drive yet?
