Pioneer Firmware?
TallyD
Pioneer Firmware?
#1 Post by TallyD » Fri Dec 12, 2025 11:19 am
I'm no longer able to rip anything, i think I need a firmware update is there a firmware for BD-RE PIONEER BD-RW BDR-XD07 1.06 BADL009209WL
Thanks for any guidance.
Re: Pioneer Firmware?
#2 Post by Coopervid » Fri Dec 12, 2025 12:20 pm
TallyD wrote: Fri Dec 12, 2025 11:19 am I'm no longer able to rip anything, i think I need a firmware update is there a firmware for BD-RE PIONEER BD-RW BDR-XD07 1.06 BADL009209WL
Post your Makemkv info. Describe your problem.
TallyD
#3 Post by TallyD » Fri Dec 12, 2025 12:25 pm
The info in makemkv if the model mentioned in post .
Error -
Backup failed
Using LibreDrive mode (v01.0 id=CE57F5EBAA83)
Badking up disc into folder "E:/rip
This disc uses newer version of AACS protection. Please let us know about it by visiting http://www.makemkv.com/a/?XQbOeERpQF3dmx..
Saved AACS dump file as E:/temp/MKB v82 DARE 29BA.tgz
Backup failed
#4 Post by Coopervid » Fri Dec 12, 2025 12:45 pm
TallyD wrote: Fri Dec 12, 2025 12:25 pm The info in makemkv if the model mentioned in post .
Error -
Backup failed
Backup failed
The problem is the disc not the drive. Makemkv doesn't yet support this disc. Install KEYDB.cfg after reading this:
viewtopic.php?f=12&t=38293
TallyD
#5 Post by TallyD » Fri Dec 12, 2025 1:38 pm
I was told this doesn't work with Pioneer drives ??
#6 Post by Coopervid » Fri Dec 12, 2025 1:43 pm
TallyD wrote: Fri Dec 12, 2025 1:38 pm I was told this doesn't work with Pioneer drives ??
You can't submit disc info from a Pioneer drive but you can still load KEYDB.cfg. Your disc has already been submitted by others with a LG drive.
viewtopic.php?f=8&t=39590&p=185058&hilit=DARE#p185058
#7 Post by MartyMcNuts » Sat Dec 13, 2025 12:01 am
For standard blu-ray a dump from any drive will work, even Pioneer. It's just for UHD discs that the public KeyDB can't use some Pioneer dumps.
Also, how in the heck did you get from "unable to read a disc" to "I think I need a firmware update"????? Firmware updates have absolutely nothing, zero, nadda to do with reading discs. If your drive has LibreDrive enabled DO NOT EVER update the drive's firmware.
I mean, the log tells you: This disc uses newer version of AACS protection.
This is a decryption issue, nothing to do with firmware.
