Pioneer Firmware?
TallyD
Pioneer Firmware?
Post by TallyD »
I'm no longer able to rip anything, i think I need a firmware update is there a firmware for BD-RE PIONEER BD-RW BDR-XD07 1.06 BADL009209WL
Thanks for any guidance.
Re: Pioneer Firmware?
TallyD wrote:
Fri Dec 12, 2025 11:19 am
Post your Makemkv info. Describe your problem.
TallyD
Post by TallyD »
The info in makemkv if the model mentioned in post .
Error -
Backup failed
Using LibreDrive mode (v01.0 id=CE57F5EBAA83)
Badking up disc into folder "E:/rip
This disc uses newer version of AACS protection. Please let us know about it by visiting http://www.makemkv.com/a/?XQbOeERpQF3dmx..
Saved AACS dump file as E:/temp/MKB v82 DARE 29BA.tgz
Backup failed
TallyD wrote:
Fri Dec 12, 2025 12:25 pm
Error -
Backup failed
Backup failed
The problem is the disc not the drive. Makemkv doesn't yet support this disc. Install KEYDB.cfg after reading this:
viewtopic.php?f=12&t=38293
TallyD
Post by TallyD »
I was told this doesn't work with Pioneer drives ??
TallyD wrote:
Fri Dec 12, 2025 1:38 pm
You can't submit disc info from a Pioneer drive but you can still load KEYDB.cfg. Your disc has already been submitted by others with a LG drive.
viewtopic.php?f=8&t=39590&p=185058&hilit=DARE#p185058
For standard blu-ray a dump from any drive will work, even Pioneer. It's just for UHD discs that the public KeyDB can't use some Pioneer dumps.
Also, how in the heck did you get from "unable to read a disc" to "I think I need a firmware update"????? Firmware updates have absolutely nothing, zero, nadda to do with reading discs. If your drive has LibreDrive enabled DO NOT EVER update the drive's firmware.
I mean, the log tells you: This disc uses newer version of AACS protection.
This is a decryption issue, nothing to do with firmware.
