AACS 82 disc dump New Order Low-Life
SunByrne
Post by SunByrne »
Just got this one in the mail, fails with "This disc uses newer version of AACS protection."
Re: AACS 82 disc dump New Order Low-Life
You should email those dumps to svq@makemkv.com so a key can be created for MakeMKV's built in hashed key mechanism. A few days after emailing the dump, try the disc again and if a key is available, MakeMKV will download it automatically in the background.
There is a separate second decryption mechanism that MakeMKV supports, the public KeyDB. To contribute to the public KeyDB, use the template and follow the instructions in the first post in the Public KeyDB Disc Submissions thread. Instructions for downloading the keyDB and using with MakeMKV are also in that thread.
vcolfari
Post by vcolfari »
I haven't been able to rip any of the three New Order BD-As, and I see the dumps for all have been submitted. The FindVUK site is bringing up 404 pages. Has anyone been able to rip these?
vcolfari wrote:
Sun Dec 14, 2025 6:40 pm
The website for keyDB is HTTP only, not HTTPS. Some web browsers default to HTTPS only.
Schu20
Post by Schu20 »
I just had the same issue with the Ultravox Collection box set and the Fine Young Cannibals The Raw & The Cooked blu rays. Log files were submitted.
vcolfari
Post by vcolfari »
dcoke22 wrote:
Mon Dec 15, 2025 5:40 am
Using http solved the issue. Thank you!
Wildgift
Post by Wildgift »
I'm having the same problem for all 3 of the New Order BRs. Any fixes?
