DVD read issue?
DVD read issue?
So I bought the complete Monk series - when I load up the disc in MKV, in my blu-ray drive and DVD drive I see only 2 episodes. I know there are three episodes on the disc because it loads that way in my DVD player, I can watch all three. How would I get the other episode to show up? I've tried auto in MKV even opening the dic manually but I still only see 2 episodes. The disc is clean as far as I can tell....
- Screenshot 2025-12-07 at 3.59.36 PM.png (304.76 KiB) Viewed 19359 times
- Screenshot 2025-12-07 at 3.56.52 PM.png (134.92 KiB) Viewed 19359 times
Re: DVD read issue?
You can try to check another DVD opening mode, sometimes it helps: viewtopic.php?f=7&t=28541
Re: DVD read issue?
Ive tried all modes (CellWalk, CellTrim and CellFull) and still can't get all the episodes to list - anything else I can try?
Re: DVD read issue?
What does it list, when you use "Open DVD files manually" from the file menu?
Re: DVD read issue?
Its shows only 2 episodes - but when the DVD player on my Mac starts up, I see all three episodes
