Pioneer BDR-UD03 UHD possibility
Re: Pioneer BDR-UD03 UHD possibility
takashi112 wrote: Wed Dec 10, 2025 10:03 pm Hi All,
I am new and i have this
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number:
Firmware date: 2020-06-15
Drive platform: RS8511
Firmware version: 1.14
i dont think its detecting 4k drives
do i need to flash it?
PM sent.
ab324545
Post by ab324545 »
Hi! Getting in line for some help for enabling UHD disks on this drive. Thanks in advance, I really appreciate it!
Revision: 1.14
Serial number: CIDL50XXXXXX
Highest AACS version: 82
ab324545 wrote: Thu Dec 11, 2025 2:17 am Hi! Getting in line for some help for enabling UHD disks on this drive. Thanks in advance, I really appreciate it!
Revision: 1.14
Pm is coming. Reload your browser in a minute.
Cheesy4036
Post by Cheesy4036 »
Hi, can this be enabled for UHD discs? Thanks for looking!
OS device name: H:
Manufacturer: ASUS
Product: SBW-06D5H-U
Revision: E102
Serial number: CLDLXXXXXXX
Firmware date: 2023-04-20
Highest AACS version: 68
Firmware version: E102/ID26
Librarian
takashi112
Post by takashi112 »
Coopervid wrote: Wed Dec 10, 2025 11:30 pm
Revision: 1.14
Serial number:
PM sent.
Thank you so much. It was able to read blue ray disks before. However after the flash, it keeps crashing my server. I am using HP EliteDesk 800 G4 DM i7-8700T 16GB RAM 512GB linux.
I am using the verbatim slimline drive
Do any of you know what this issue is ?
You need to remove power and USB from the drive after flashing. And Verbatim enclosures are very power hungry. Make sure that the drive is connected to USB-C or a powered USB hub.
MrRay
Post by MrRay »
I have this exact configuration, can I get the steps as well?
Coopervid wrote: Thu Dec 11, 2025 3:42 pm
Revision: 1.14
MrRay wrote: Mon Dec 15, 2025 2:22 pm I have this exact configuration, can I get the steps as well?
Revision: 1.14
PM sent.
flagcourier
Post by flagcourier »
Getting in on this.
OS device name: /dev/sr0
Revision: 1.14
Serial number: DDDL527954WL
Highest AACS version: 62
Cheesy4036 wrote: Thu Dec 11, 2025 7:07 pm Hi, can this be enabled for UHD discs? Thanks for looking!
OS device name: H:
Manufacturer: ASUS
Revision: E102
PM sent.
flagcourier wrote: Tue Dec 16, 2025 5:16 am Getting in on this.
Revision: 1.14
PM sent.
Coopervid wrote: Tue Dec 16, 2025 10:08 am
OS device name: H:
Manufacturer: ASUS
Revision: E102
PM sent.
This cannot be flashed as the firmware is too new. I have one too with the same firmware and nothing can be done with it.
beflapje
Post by beflapje »
Hello ,
Can i flash this drive to support UHD-BR
Vendor Product Rev
PIONEER BD-RW BDR-UD03 1.11
Interconnect: USB
SupportLevel: Unsupported
Profile Path: None
Cache: 4000k
CD-Write: -R, -RW, BUFE, CDText, Test, IndexPts, ISRC
DVD-Write: -R, -R DL, -RAM, -RW, +R, +R DL, +RW, BUFE, Test
BD-Write: -R, -RE
Strategies: CD-TAO, CD-SAO, CD-Raw, DVD-DAO
Thank you
Yes, Marty. I oversaw that the date is too new. Thanks for bringing it up.
Higgie
Post by Higgie »
Hi, is my drive a candidate for reading UHD Discs? Thanks!
Revision: 1.03
Serial number:
Firmware date: 2015-05-14
Highest AACS version: 75
Drive platform: RS8510
Firmware version: 1.03/ID19
