Ronin rips with Directors commentary
scottg73
#1 Post by scottg73 » Thu Dec 11, 2025 10:33 am
Hi
Newbie here, I've ripped over 60 discs now and not had any problems. But Ronin I can't seem to rip it without directors commentary, what am I doing wrong ?
Thanks for any help.
Scott
Re: Ronin rips with Directors commentary
#2 Post by dcoke22 » Thu Dec 11, 2025 2:54 pm
blu-ray.com suggests (https://www.blu-ray.com/movies/Ronin-4K-Blu-ray/316415/) that Ronin (1998) has DTS audio. I don't know what your playback setup is, but by default Windows Media Player does not have the codecs to decode and playback DTS audio. It can, however, play Dolby Digital AC-3 audio and often commentary tracks on movies use the more basic AC-3 codec.
The utility MediaInfo (https://mediaarea.net/en/MediaInfo) can show you a lot of details about your .mkv files, including how many and what kind of audio tracks are in them.
There are codec packs that can be downloaded and installed for Windows Media Player. Or, try VLC (https://www.videolan.org/vlc/) which can play nearly everything by default.
