Nope. Firmware is too new.locksbox wrote: Tue Dec 02, 2025 6:29 pm Hi there,
Is it possible to firmware fix my Pioneer BD-RW BDR-S09 sadly I have the last firmware 1.55, I suspect it won't be able to.
Many thanks.
The details are below:
Manufacturer: PIONEER
Product: BD-RW BDR-S09
Revision: 1.55
Serial number: [removed]
Firmware date: 2023-02-16
Drive platform: RS8600
Firmware version: 1.55/ID43
PIONEER BDR-209 change the Firmware ?
Re: PIONEER BDR-209 change the Firmware ?
locksbox
Thank you for the info MartyMcNuts, I thought it might be the case, shame.
mossman1120
I am also in need of flashing my BDR-209s to be UHD friendly. Would it be possible to me help me as well. Thanks!
Product: BD-RW BDR-209D
Revision: 1.33
Serial number:
Firmware date: 2015-12-09
Bus encryption flags: 13
Firmware version: 1.33/ID61
Revision: 1.10
Serial number:
Firmware date: 2013-09-10
Firmware version: 1.10/ID61
Revision: 1.10
Serial number:
PM sent. Applies for all of your drives.mossman1120 wrote: Sat Dec 06, 2025 12:51 am I am also in need of flashing my BDR-209s to be UHD friendly. Would it be possible to me help me as well. Thanks!
Drive Information Manufacturer: PIONEER Product: BD-RW BDR-209D Revision: 1.33 Serial number: Firmware date: 2015-12-09 Bus encryption flags: 13 LibreDrive Information Status: Enabled Drive platform: RS8600 Firmware name: PIONEER BDR-209 Firmware type: Original (unpatched) Firmware version: 1.33/ID61 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes No disc insertedCode: Select all
Drive Information Manufacturer: PIONEER Product: BD-RW BDR-209D Revision: 1.10 Serial number: Firmware date: 2013-09-10 Bus encryption flags: 13 LibreDrive Information Status: Enabled Drive platform: RS8600 Firmware name: PIONEER BDR-209 Firmware type: Original (unpatched) Firmware version: 1.10/ID61 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes No disc insertedCode: Select all
mossman1120
Thanks worked like a charm!Coopervid wrote: Sat Dec 06, 2025 10:38 amPM sent. Applies for all of your drives.mossman1120 wrote: Sat Dec 06, 2025 12:51 am I am also in need of flashing my BDR-209s to be UHD friendly. Would it be possible to me help me as well. Thanks!
aguywithadrive
Hi
I am also in need of flashing my BDR-209D to be UHD friendly.
Would it be possible to help me as well? Thanks!
OS device name: E:
Revision: 1.51
Serial number:
Firmware date: 2018-05-08
Highest AACS version: 58
Drive platform: RS8601
Firmware version: 1.51/ID61
OS device name: E:
Revision: 1.51
Serial number:
PM is coming.aguywithadrive wrote: Wed Dec 10, 2025 10:01 pm Hi
OS device name: E:
Revision: 1.51
Serial number:
chiark
I too have a BDR-209 that's old, but still good, that I'm looking to flash to support UHD. Hopefully this can be done pretty easily?
Many thanks!
OS device name: F:
Product: BD-RW BDR-209M
Revision: 8.11
Serial number: QHDL135344WL
Firmware date: 2014-01-16
Highest AACS version: 81
Firmware version: 8.11/ID52
Many thanks!
OS device name: F:
Revision: 8.11
chiark
I emailed Billy who replied within minutes, and now have a working UHD drive - thank you!
chipyto
Información de unidad de disco
Nombre del SO del dispositivo: M:
Fabricante: PIONEER
Producto: BD-RW BDR-209D
Revisión: 1.51
Número de serie: SBDL039088WL
Fecha del firmware: 2018-05-08
Marcas de cifrado bus: 13
Fabricante: PIONEER
Revisión: 1.51
PM is coming.chipyto wrote: Mon Dec 15, 2025 3:16 pm Hi,
Fabricante: PIONEER
Revisión: 1.51
chipyto
Donation Sent
Thank you Coopervid.
Another thing, please, it is possible to dump bin before flashing ?
Thank you
Chipyto
Thank you
Chipyto
No. But if you ever need to flash back to original just PM me or post in the forum.chipyto wrote: Mon Dec 15, 2025 7:29 pm Donation Sent
Thank you
Chipyto
chipyto
Ok.
Thank you again for your help
Nice to meet you
Merry XMAS !!!
Best Regards,
Carlos from Madrid ( Spain )
Nice to meet you
Merry XMAS !!!
Best Regards,
alh22
Another Pioneer BDR-209M owner here, this one inside a Buffalo BRXL-16U3.
This drive neither sees nor reads Blu-ray discs. Would you have a firmware update/patch to fix this?
