Yes it has been discontinued, its the same hardware as the lg wh16/14 series just rebranded by asus. I found that the owc mercury sells the lg wh16ns40 with their case for 179, pricy but about the only place you can still find these... if you want you can cross flash it to the asus firmware but there really isn't a point.rayians wrote: Tue Dec 09, 2025 12:49 pm I have been trying to find an Asus BW-16D1HT to flash for about 2 months. They used to be $99, then went up to $129, then several hundred dollars, and now for the past month there is absolutely none to be had anywhere. Can anyone confirm or deny if these have been discontinued? If not, is there any idea when they will be available again. If they are gone, what is a good alternative that is readily available?
blind-s33r
Thank you, Billy, I emailed you this morning.
Yes, it was discontinued more than 12 months ago. Now it appears the LG drives have also been discontinued. So, basically there are no more UHD compatible (or flashable) drives being manufactured at all.rayians wrote: Tue Dec 09, 2025 12:49 pm I have been trying to find an Asus BW-16D1HT to flash for about 2 months. They used to be $99, then went up to $129, then several hundred dollars, and now for the past month there is absolutely none to be had anywhere. Can anyone confirm or deny if these have been discontinued? If not, is there any idea when they will be available again. If they are gone, what is a good alternative that is readily available?
parkerpeter
I have an LG BU40N drive, MakeMKV shows the following:
OS device name: /dev/sr0
Product: BD-RE BU40N
Revision: 1.05
Serial number: MZFP7MD4234
I have tried to flash the 1.03 MK firmware (on Linux Mint) using the command: sudo makemkvcon f -v -d /dev/sr0 -f /tmp/sdf.bin rawflash enc -i /tmp/HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
I get the response "Loaded SDF.bin version 0xa3" and then nothing else, it just hangs. If I ctrl-c out and re-check the firmware it is still 1.05. Output of makemkvcon f -l is:
Found 1 drives(s)
00: dev_21:1, /dev/sr0, /dev/sr0
HL-DT-ST_BD-RE_BU40N_1.05_212404231347_MZFP7MD4234
Any guidance on what I'm doing wrong and how to proceed would be greatly appreciated.
Revision: 1.05
Found 1 drives(s)
Thank you for this guide! It and the firmware helped me out greatly! I only have two movies on UHD, but knowing that my LG drive can read them now is awesome.
This is from the guide:parkerpeter wrote: Wed Dec 10, 2025 9:48 am Hello,
Revision: 1.05
Found 1 drives(s)
or ./makemkvcon f -d '/IOBDServices/D5D25996' -f /tmp/sdf.bin rawflash enc -i /tmp/your firmware filename here
if your firmware is on the encrypted list
and you should replace /dev/sr0 with dev_21:1
TypicalPsycho
Hi all. First time poster, first time visitor, first time ripper! I have a similar spec unit to the one described in this thread (info below). I've done some reading on page 1 of this thread and don't see anything on my unit, but it looks like we can handle this in a PM. Here's my specs, TIA!
Verbatim 43888 branded
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number:
Firmware date: 2020-06-15
Highest AACS version: 25
Drive platform: RS8511
Firmware version: 1.14
Disc Information
Label: IRON_MAN_D1
Timestamp: 2008-08-11 21:24:44
Protection: AACS v7
Data capacity: 44.0 Gb
Disc type: BD-ROM
Number of layers: 2
Was able to rip a 1080P DVD, but no go on 4k UHD. Need 4k BluRay too. Backup not available either for UHD...
There's something wrong there because the Verbatim 43888 should contain a Pioneer BDR-UD04 which has native UHD support.TypicalPsycho wrote: Fri Dec 12, 2025 1:21 amHi all. First time poster, first time visitor, first time ripper! I have a similar spec unit to the one described in this thread (info below). I've done some reading on page 1 of this thread and don't see anything on my unit, but it looks like we can handle this in a PM. Here's my specs, TIA!
Revision: 1.14
Serial number:
Disc Information
Label: IRON_MAN_D1
Protection: AACS v7
Disc type: BD-ROM
Number of layers: 2
Note that the Pioneer models are no longer available and now the 43888 contains an LG BU40N.
Exactly. I'd say TypicalPsycho has either a 43887 or a 43890.Mr_Orange wrote: Fri Dec 12, 2025 3:57 amThere's something wrong there because the Verbatim 43888 should contain a Pioneer BDR-UD04 which has native UHD support.TypicalPsycho wrote: Fri Dec 12, 2025 1:21 amHi all. First time poster, first time visitor, first time ripper! I have a similar spec unit to the one described in this thread (info below). I've done some reading on page 1 of this thread and don't see anything on my unit, but it looks like we can handle this in a PM. Here's my specs, TIA!
Revision: 1.14
Serial number:
Disc Information
Label: IRON_MAN_D1
Protection: AACS v7
Disc type: BD-ROM
Number of layers: 2
PM sent. The guys are right. This is not a 43888.TypicalPsycho wrote: Fri Dec 12, 2025 1:21 amHi all. First time poster, first time visitor, first time ripper! I have a similar spec unit to the one described in this thread (info below). I've done some reading on page 1 of this thread and don't see anything on my unit, but it looks like we can handle this in a PM. Here's my specs, TIA!
Revision: 1.14
Serial number:
Disc Information
Label: IRON_MAN_D1
Protection: AACS v7
Disc type: BD-ROM
Number of layers: 2
Hello, I was wondering if my Pioneer BDR-209D could be crossflashed for UHD compatibility. Firmware from 2016. Drive Info below. Thanks
OS device name: I:
Product: BD-RW BDR-209D
Revision: 1.34
Serial number:
Firmware date: 2016-04-25
Bus encryption flags: 13
Highest AACS version: 81
Drive platform: RS8600
Firmware version: 1.34/ID61
OS device name: I:
Revision: 1.34
Serial number:
PM sent.st33lerz wrote: Fri Dec 12, 2025 2:21 pm Hello, I was wondering if my Pioneer BDR-209D could be crossflashed for UHD compatibility. Firmware from 2016. Drive Info below. Thanks
OS device name: I:
Revision: 1.34
Serial number:
HI Im new
I got from Amazon US two weeks ago and got this Verbatim.
Im on Mac can I flash there if not I can use my brother windows/ubuntu , in that case where is better to flash it?
should I use this file BU40N_1.03_MK.bin ?
Revision: 1.02
Serial number: MO5P56D3749
Bus encryption flags: 1F
Highest AACS version: 65
Harware support: Yes
Firmware support: No
Firmware version: 1.02
Unrestricted read speed: Possible (with patched firmware)-
BlueRogue44
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: DHDL119818WL
Firmware date: 2020-07-21
Drive platform: RS8F00
Firmware version: E113/ID76
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
My Drive says the following in MakeMKV
OS device name: F:
Manufacturer: ASUS
Product: SBW-06D2X-U
Revision: A102
Serial number:
Firmware date: 2121-06-28 13:41
Could you assist please?
OS device name: F:
Manufacturer: ASUS
Revision: A102
Serial number:
