Hello!
I have a Pioneer BD-208DBK that is running the original firmware. I know this because the firmware has never been up- or down-graded. On the device is the following: MFD NOVEMBER 2012.
Pioneer Japan has a firmware update to get the device to version 1.50. There is also a warning: "Once updated to version 1.50, this drive will not revert to older firmware versions."
Should I flash the firmware with the Pioneer software to 1.50 and then flash it with makemkv, or just skip the Pioneer-sourced flash altogether? I don't want to create an issue in case the firmware would need to be downgraded.
Many thanks!
Pioneer BD 208D: Upgrade in which order?
Re: Pioneer BD 208D: Upgrade in which order?
Copy and paste the MakeMKV drive info and libredrive info sections before you do anything.birdbrain wrote: Tue Dec 09, 2025 6:42 am Hello!
Many thanks!
Manufacturer: PIONEER
Product: BD-RW BDR-208D
Revision: 1.10
Serial number: .....
Firmware date: 2012-08-22
Bus encryption flags: 13
Drive platform: RS8301
Firmware name: PIONEER BDR-208
Firmware version: 1.10/ID61
Pioneer Japan has an option to update (as mentioned) to either 1.40 or 1.50 in case either of those versions would get this drive to the right place.
In any case, thanks!
Revision: 1.10
Don't update the drivebirdbrain wrote: Wed Dec 10, 2025 3:38 am Drive Information
Revision: 1.10
Serial number: LKDL029127WL
Email me the drive info for the flasher see below for details
