callumw
#1486
Post
by callumw » Sat Dec 06, 2025 9:12 pm
First time trying this with a UHD drive (my old bluray still works like a champ)
The PC looks like it recognises discs ok, but in MakeMKV it doesn't look right.
It sees the drive as:
OS device name: F:
Manufacturer: 000000
Product: 9999999999999999
Revision: 1.05
Serial number: MOFP7MD4032
Highest AACS version: 81
The drive label says :
Hitachi-LG BU40N
Manufactured:
July 2025
Firmware Version
1.05
The SDFTool pops up an error when I tried to backup the fimware:
The drive you have selected does not have the correct drive platform (MT 1959) and cannot be flashed"
Would I be right in thinking the problem is the cable I'm got for it?
It's SATA > USB
Drive:
https://www.amazon.co.uk/dp/B071CPRK74
Cable:
https://www.amazon.co.uk/dp/B073QNN1C5
#1487
Post
by Billycar11 » Sat Dec 06, 2025 10:36 pm
callumw wrote: Sat Dec 06, 2025 9:12 pm
OS device name: F:
Revision: 1.05
Hitachi-LG BU40N
Manufactured:
July 2025
Firmware Version
1.05
It's SATA > USB
Drive:
Cable:
Your case is junk get a recommend adapter from the guide below and a sata to slim sata adapter and it will work
BryanS
#1488
Post
by BryanS » Mon Dec 08, 2025 9:05 pm
I have a BP60NB10 drive that I flashed and it was working great. Drive stated having issues reading discs, so LG said I can send it back to get it replaced since it is under warranty. But in order to do that I need to flash the original firmware back on it. Is that something I can do? If so, how? I was looking at the recover option, but when it comes to selecting the correct new firmware, I didn't know what I would choose.
Any help would be appreciated
Thanks,
Bryan
Bumbles
#1489
Post
by Bumbles » Tue Dec 09, 2025 2:15 pm
All working as hoped. However, if you try to flash the drive while the disk drive tray is ejected SDFTool throws an error with an error number. Would it be possible to check the status of the drive tray and throw a more human readable error if it's currently out?
callumw
#1490
Post
by callumw » Tue Dec 09, 2025 2:32 pm
Returned the drive and replaced it with a Verbatim 43888 (
https://www.amazon.co.uk/dp/B07MTP9VKX )
Much much nicer drive and comes with the cables and adapter options.
Easy firmware backup then install of DE_LG_BU40N_1.03_MK.bin
Currently testing with our Apollo11 UHD disk and it's doing its thing.
Thanks @Billycar11 for the nudge in the right direction
Pre:
OS device name: F:
Product: BD-RE BU40N
Revision: 1.05
Serial number: poipoipopoi
Post:
OS device name: F:
Revision: 1.03
#1491
Post
by MartyMcNuts » Tue Dec 09, 2025 10:55 pm
Bumbles wrote: Tue Dec 09, 2025 2:15 pm
Um, no. It is just a GUI for the sdftool CLI so whatever error it spits out is it.
merlinthesage
#1492
Post
by merlinthesage » Tue Dec 09, 2025 11:58 pm
When I load up SDFtool Flasher 1.3.6
it says my drive isnt a MT1959?
How do I fix this? It should be a 1959 drive
OS device name: J:
Revision: 1.02
Serial number: MO7P5692121
Bus encryption flags: 1F
Harware support: Yes
Firmware support: No
Firmware version: 1.02
is something wrong?
RFAurora
#1493
Post
by RFAurora » Wed Dec 10, 2025 12:51 am
I downloaded the sdftool flasher for my PC to try and use it for my Blu-Ray player, but when I open the tool, the box opens like this and I can't resize it to use it I have a Windows 11 PC.
blind-s33r
#1494
Post
by blind-s33r » Wed Dec 10, 2025 1:11 am
RFAurora wrote: Wed Dec 10, 2025 12:51 am
Cough
NOTE: If the GUI looks a bit deformed (happens on a 4k monitor), you can right click the exe and select properties. In the compatibility tab, click "Change high DPI settings" then under "High DPI scaling override" tick the box and select "System (Enhanced)" in the dropbox.
Cough
RFAurora
#1495
Post
by RFAurora » Wed Dec 10, 2025 1:42 am
blind-s33r wrote: Wed Dec 10, 2025 1:11 am
Cough
Cough
Thank you.
McMurphy66
#1496
Post
by McMurphy66 » Thu Dec 11, 2025 4:43 pm
Thank you Marty, I finally received my UHD blu rays from storage and the Buffalo flashed drive works a treat - faster than expected. I really do appreciate all the work you do! Be lucky.
McMurphy66 wrote: Wed Dec 03, 2025 12:47 pm
MartyMcNuts wrote: Wed Dec 03, 2025 7:10 am
[quote=McMurphy66 post_id=189135 time=<a href="tel:1764735582">1764735582</a> user_id=104006]
Apologies if this is in the wrong thread…newbie post but not new to the amazing makemkv software.
Bought the Buffalo BRUHD-PU3-BK. Read through the threads and wasn’t sure if it was BUN-40 flash process. I’m confused what to use, not done this before.
Thanks all.
OS device name: E:
Manufacturer: BUFFALO
Product: Optical Drive
Revision: BN14
Serial number:
Firmware date: 2121-06-21 13:33
Highest AACS version: 48
Yes, it's a BU40N. You can flash it to BU40N 1.03-MK.
Thank you Marty, I really appreciate your reply.
I’ll use the LG BU40N 1.03mk. Is it simply ‘select drive’ “select write’ open this firmware from the pack and start?
[/quote]
#1497
Post
by MartyMcNuts » Thu Dec 11, 2025 10:50 pm
McMurphy66 wrote: Thu Dec 11, 2025 4:43 pm
Thanks all.
OS device name: E:
Revision: BN14
Serial number:
[/quote]
Yep.
ArifHubble23
#1498
Post
by ArifHubble23 » Fri Dec 12, 2025 2:56 pm
Please don't shoot me! I am rather computer illiterate! Apologies to anyone who has a migraine from the questions I am about to ask.
New drive: Verbatim 43890 USB 3.2
Issue: not reading UHD 4K discs but can see the disc title on PC- Make MKV 'hash error' occurs
Make MKV drive log:
Revision: 1.05
Serial number: MO1P6AE5410
Highest AACS version: 77
If someone could advise on what firmware to flash to this drive to enable UHD compatibility I would be grateful. Much thanks.
Mr_Orange
#1499
Post
by Mr_Orange » Fri Dec 12, 2025 10:43 pm
ArifHubble23 wrote: Fri Dec 12, 2025 2:56 pm
Make MKV drive log:
Revision: 1.05
Flash BU40N 1.03MK.
ArifHubble23
#1500
Post
by ArifHubble23 » Sat Dec 13, 2025 11:09 am
Many thanks!
