Avatar blu-ray failed to open no FUTs
Firstatom
Post by Firstatom » Tue Dec 09, 2025 8:31 pm
Error "BD+ code processed but no FUTs were obtained, errors may follow"
Using LibreDrive mode (v06.3 id=7FA2657C7667)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/generic.svq
Screenshot 2025-12-09 142210.png (15.51 KiB) Viewed 1812 times
Firstatom
Re: Avatar blu-ray failed to open no FUTs
Post by Firstatom » Tue Dec 09, 2025 8:43 pm
I tried opening the disc 3 times and got the same error each time. I restarted the computer and decided to try once more and that seemed to work. I was able to get the the file selection. Its saving the file now. Will Post a update with the results.
