You need to post your Makemkv info. Afterwards you will receive instructions for flashing your drive for UHDs.mossman1120 wrote: ↑Sun Nov 30, 2025 9:08 amI would be looking to UHD. Is the cross flashing something that I could do myself? I have previous flashed LG drives.MartyMcNuts wrote: ↑Sun Nov 30, 2025 8:58 amFor standard blu-ray, yes. For UHD no. If the firmware is pre 12/2022 it can be cross-flashed to a UHD model firmware.mossman1120 wrote: ↑Sun Nov 30, 2025 8:49 amI just want to make sure I am understanding correctly.
Based on the SDF update November 2025 I see that there are a bunch of BDR-209D firmware versions listed:Would this mean that a a BDR-209DBK (I am going to assume that BK means black) manufactured in 2022 it should now work?Code: Select all
PIONEER-BD-RW___BDR-209D-1.10-44290838-8600ID61-20130910 PIONEER-BD-RW___BDR-209D-1.20-90EB76E2-8600ID61-20140408 PIONEER-BD-RW___BDR-209D-1.30-6901C899-8600ID61-20141205 PIONEER-BD-RW___BDR-209D-1.31-8CF13BF3-8600ID61-20150525 PIONEER-BD-RW___BDR-209D-1.32-F3AD8FFF-8600ID61-20150825 PIONEER-BD-RW___BDR-209D-1.33-CC733748-8600ID61-20151209 PIONEER-BD-RW___BDR-209D-1.34-FCF25369-8600ID61-20160425 PIONEER-BD-RW___BDR-209D-1.50-7F6800F0-8600ID61-20171221 PIONEER-BD-RW___BDR-209D-1.50-F67F9D64-8601ID61-20171221 PIONEER-BD-RW___BDR-209D-1.51-148709AB-8600ID61-20180508 PIONEER-BD-RW___BDR-209D-1.51-664813FF-8601ID61-20180508
If the drive is manufactured before 12/2022 would that mean the firmware is okay? Would the version be on the label or it is something that would need to be dumped from the drive?
All Pioneer drives will be LibreDrive supported
Re: All Pioneer drives will be LibreDrive supported
mossman1120
So noted. For this model is there something to look for to make sure the firmware allows for flashing? Is the manufacture date sufficient?Coopervid wrote: ↑Sun Nov 30, 2025 11:31 amYou need to post your Makemkv info. Afterwards you will receive instructions for flashing your drive for UHDs.mossman1120 wrote: ↑Sun Nov 30, 2025 9:08 amI would be looking to UHD. Is the cross flashing something that I could do myself? I have previous flashed LG drives.MartyMcNuts wrote: ↑Sun Nov 30, 2025 8:58 am
Post your Makemkv info.
mossman1120
My crystal ball seems to be too dull. Get the drive and if it has firmware younger than 12/2022 it's fine. If not, return it.mossman1120 wrote: ↑Sun Nov 30, 2025 2:39 pmI don’t have it yet otherwise I would. Trying to avoid getting stuck with a drive that I can’t use.
BendingTorx
Here's a spare I just picked up from a yard sale, chinese box and all. Looks like the firmware is very recent. I'm wondering if it's possible with this one?
OS device name: E:
Current profile: DVD-ROM
Manufacturer: PIONEER
Product: BD-RW BDR-XD08
Revision: 1.04
Serial number:
Firmware date: 2024-10-09
Drive platform: Pioneer RS9330
Firmware version: GENE
OS device name: E:
Revision: 1.04
Serial number:
Hey @Mossman1120, got your DM. Sorry, did not have notifications on. Did you get a drive?mossman1120 wrote: ↑Sun Nov 30, 2025 2:39 pmI don’t have it yet otherwise I would. Trying to avoid getting stuck with a drive that I can’t use.
No, the firmware is post 11/2022 so cannot be cross-flashed for UHD compatibility but you can enable libredrive for standard blu-ray discs. Just download the latest SDF.bin and put it in the MakeMKV data directory then restart MakeMKV.BendingTorx wrote: ↑Tue Dec 09, 2025 7:59 pmHere's a spare I just picked up from a yard sale, chinese box and all. Looks like the firmware is very recent. I'm wondering if it's possible with this one?
OS device name: E:
Revision: 1.04
Serial number:
BendingTorx
Thank you for the swift reply! I've missed forums hahaMartyMcNuts wrote: ↑Tue Dec 09, 2025 10:46 pmNo, the firmware is post 11/2022 so cannot be cross-flashed for UHD compatibility but you can enable libredrive for standard blu-ray discs. Just download the latest SDF.bin and put it in the MakeMKV data directory then restart MakeMKV.BendingTorx wrote: ↑Tue Dec 09, 2025 7:59 pmHere's a spare I just picked up from a yard sale, chinese box and all. Looks like the firmware is very recent. I'm wondering if it's possible with this one?
OS device name: E:
Revision: 1.04
Serial number:
Will this firmware date eventually be possible to be cross-flashed? And I did add the sdf bin file, should the info panel be saying that libredrive is enabled now?
Once you add the SDF.bin file to the MakeMKV data directory (where the dumps and private_data.tar file are located) you need to power cycle the drive and restart MakeMKV. The SDF.bin file will be absorbed into the private_data.tar file and LibreDrive should be enabled. If it still isn't enabled, insert a blu-ray disc into the drive and MakeMKV should create a firmware dump in the data directory for you to email to support@makemkv.com.BendingTorx wrote: ↑Tue Dec 09, 2025 11:12 pmThank you for the swift reply! I've missed forums hahaMartyMcNuts wrote: ↑Tue Dec 09, 2025 10:46 pmNo, the firmware is post 11/2022 so cannot be cross-flashed for UHD compatibility but you can enable libredrive for standard blu-ray discs. Just download the latest SDF.bin and put it in the MakeMKV data directory then restart MakeMKV.BendingTorx wrote: ↑Tue Dec 09, 2025 7:59 pmHere's a spare I just picked up from a yard sale, chinese box and all. Looks like the firmware is very recent. I'm wondering if it's possible with this one?
OS device name: E:
Revision: 1.04
Serial number:
Good morning,
I have tried to get this to work on my drive with no look, my info is:
Product: BD-RW BDR-S13U
Revision: 1.04
Serial number: CEDL000416WL
Firmware date: 2022-12-12
Highest AACS version: 65
Drive platform: RS9201
Firmware name: PIONEER BDR-213T
Firmware version: 1.04/ID43
I get the following error
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
Downloading latest HK to C:\Users\steve/.MakeMKV ...
Can anyone help?
I have tried putting the file in the mkv folder, following the all the steps, i have tried uninstalling the software then deleting all folders and rebooting and reinstalling and this morning I have taken the drive into work and using a different pc and still getting the same issues, im not sure what i am doing wrong? Thanks for the help
Revision: 1.04
Can anyone help?
Your drive is good to go. I suggest you power off the PC and drive for a few minutes before trying again.Stevey wrote: ↑Fri Dec 19, 2025 8:40 amGood morning,
Revision: 1.04
Can anyone help?
Thanks for the reply MartyMcNuts, I have tried turning it off and on again and it still comes up with the same error. I have taken the drive to my work and tried on my work PC with a fresh install of MakeMKV and still the same error. I have also tried with different Disc's and still get the same error. Blue rays work fine but no 4K discs work, they all come up with this error
oops wrong thread
FYI it all seems to be working well now, thanksStevey wrote: ↑Fri Dec 26, 2025 6:15 pmThanks for the reply MartyMcNuts, I have tried turning it off and on again and it still comes up with the same error. I have taken the drive to my work and tried on my work PC with a fresh install of MakeMKV and still the same error. I have also tried with different Disc's and still get the same error. Blue rays work fine but no 4K discs work, they all come up with this error![]()
