blind-s33r
Post by blind-s33r » Tue Dec 09, 2025 1:26 pm
rayians wrote:
Tue Dec 09, 2025 12:49 pm
I have been trying to find an Asus BW-16D1HT to flash for about 2 months. They used to be $99, then went up to $129, then several hundred dollars, and now for the past month there is absolutely none to be had anywhere. Can anyone confirm or deny if these have been discontinued? If not, is there any idea when they will be available again. If they are gone, what is a good alternative that is readily available?
Yes it has been discontinued, its the same hardware as the lg wh16/14 series just rebranded by asus. I found that the owc mercury sells the lg wh16ns40 with their case for 179, pricy but about the only place you can still find these... if you want you can cross flash it to the asus firmware but there really isn't a point.
Bourney0
Post by Bourney0 » Tue Dec 09, 2025 6:31 pm
Thank you, Billy, I emailed you this morning.
Post by MartyMcNuts » Tue Dec 09, 2025 10:53 pm
Yes, it was discontinued more than 12 months ago. Now it appears the LG drives have also been discontinued. So, basically there are no more UHD compatible (or flashable) drives being manufactured at all.
parkerpeter
Post by parkerpeter » Wed Dec 10, 2025 9:48 am
I have an LG BU40N drive, MakeMKV shows the following:
OS device name: /dev/sr0
Product: BD-RE BU40N
Revision: 1.05
Serial number: MZFP7MD4234
I have tried to flash the 1.03 MK firmware (on Linux Mint) using the command: sudo makemkvcon f -v -d /dev/sr0 -f /tmp/sdf.bin rawflash enc -i /tmp/HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
I get the response "Loaded SDF.bin version 0xa3" and then nothing else, it just hangs. If I ctrl-c out and re-check the firmware it is still 1.05. Output of makemkvcon f -l is:
Found 1 drives(s)
00: dev_21:1, /dev/sr0, /dev/sr0
HL-DT-ST_BD-RE_BU40N_1.05_212404231347_MZFP7MD4234
Any guidance on what I'm doing wrong and how to proceed would be greatly appreciated.
RFAurora
Post by RFAurora » Thu Dec 11, 2025 5:06 pm
Thank you for this guide! It and the firmware helped me out greatly! I only have two movies on UHD, but knowing that my LG drive can read them now is awesome.
Post by Coopervid » Thu Dec 11, 2025 5:13 pm
Revision: 1.05
Found 1 drives(s)
This is from the guide:
or ./makemkvcon f -d '/IOBDServices/D5D25996' -f /tmp/sdf.bin rawflash enc -i /tmp/your firmware filename here
if your firmware is on the encrypted list
and you should replace /dev/sr0 with dev_21:1
TypicalPsycho
Post by TypicalPsycho » Fri Dec 12, 2025 1:21 am
Coopervid wrote:
Fri Dec 05, 2025 3:23 pm
PM sent.
Hi all. First time poster, first time visitor, first time ripper! I have a similar spec unit to the one described in this thread (info below). I've done some reading on page 1 of this thread and don't see anything on my unit, but it looks like we can handle this in a PM. Here's my specs, TIA!
Verbatim 43888 branded
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number:
Firmware date: 2020-06-15
Highest AACS version: 25
Drive platform: RS8511
Firmware version: 1.14
Disc Information
Label: IRON_MAN_D1
Timestamp: 2008-08-11 21:24:44
Protection: AACS v7
Data capacity: 44.0 Gb
Disc type: BD-ROM
Number of layers: 2
Was able to rip a 1080P DVD, but no go on 4k UHD. Need 4k BluRay too. Backup not available either for UHD...
Mr_Orange
Post by Mr_Orange » Fri Dec 12, 2025 3:57 am
PM sent.
Revision: 1.14
Serial number:
Disc Information
Label: IRON_MAN_D1
Protection: AACS v7
Disc type: BD-ROM
Number of layers: 2
There's something wrong there because the Verbatim 43888 should contain a Pioneer BDR-UD04 which has native UHD support.
Note that the Pioneer models are no longer available and now the 43888 contains an LG BU40N.
Post by MartyMcNuts » Fri Dec 12, 2025 5:51 am
PM sent.
Revision: 1.14
Serial number:
Disc Information
Label: IRON_MAN_D1
Protection: AACS v7
Disc type: BD-ROM
Number of layers: 2
Exactly. I'd say TypicalPsycho has either a 43887 or a 43890.
Post by Coopervid » Fri Dec 12, 2025 12:23 pm
PM sent.
Revision: 1.14
Serial number:
Disc Information
Label: IRON_MAN_D1
Protection: AACS v7
Disc type: BD-ROM
Number of layers: 2
PM sent. The guys are right. This is not a 43888.
st33lerz
Post by st33lerz » Fri Dec 12, 2025 2:21 pm
Hello, I was wondering if my Pioneer BDR-209D could be crossflashed for UHD compatibility. Firmware from 2016. Drive Info below. Thanks
OS device name: I:
Product: BD-RW BDR-209D
Revision: 1.34
Serial number:
Firmware date: 2016-04-25
Bus encryption flags: 13
Highest AACS version: 81
Drive platform: RS8600
Firmware version: 1.34/ID61
Post by Coopervid » Fri Dec 12, 2025 3:23 pm
OS device name: I:
Revision: 1.34
Serial number:
PM sent.
fedeb
Post by fedeb » Sat Dec 13, 2025 12:30 am
HI Im new
I got from Amazon US two weeks ago and got this Verbatim.
Im on Mac can I flash there if not I can use my brother windows/ubuntu , in that case where is better to flash it?
should I use this file BU40N_1.03_MK.bin ?
Revision: 1.02
Serial number: MO5P56D3749
Bus encryption flags: 1F
Highest AACS version: 65
Harware support: Yes
Firmware support: No
Firmware version: 1.02
BlueRogue44
Post by BlueRogue44 » Sat Dec 13, 2025 2:19 am
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: DHDL119818WL
Firmware date: 2020-07-21
Drive platform: RS8F00
Firmware version: E113/ID76
RONNIEAST
Post by RONNIEAST » Sat Dec 13, 2025 11:44 pm
My Drive says the following in MakeMKV
OS device name: F:
Manufacturer: ASUS
Product: SBW-06D2X-U
Revision: A102
Serial number:
Firmware date: 2121-06-28 13:41
Could you assist please?
