i wasn't able to decrypt new Blu-ray discs.
I've attached the dump file for your reference.
Any help on this would be greatly appreciated.
Thank you in advance.
AACS v82 Blu-ray Disc dump submission
freelunch1947
Re: AACS v82 Blu-ray Disc dump submission
Nobody 2 is AACS v82. Someone said it refused to open, but opened on a second attempt. Not for me. Dump:
mediumwave
The three New Order blu-rays are new keys. Dumps:
You should email those dumps to svq@makemkv.com so a key can be created for MakeMKV's built in hashed key mechanism. A few days after emailing the dump, try the disc again and if a key is available, MakeMKV will download it automatically in the background.
There is a separate second decryption mechanism that MakeMKV supports, the public KeyDB. To contribute to the public KeyDB, use the template and follow the instructions in the first post in the Public KeyDB Disc Submissions thread. Instructions for downloading the keyDB and using with MakeMKV are also in that thread.
A.RABID.BUFFALO
MKB_v82_The_Strangers-_Chapter_2_EA46 dump submitted
