AACS v82 Blu-ray Disc dump submission
dump109
Post by dump109 »
i wasn't able to decrypt new Blu-ray discs.
I've attached the dump file for your reference.
Any help on this would be greatly appreciated.
Thank you in advance.
MKB_v82_STXI_5008_90E2.tgz
(58.35 KiB) Downloaded 17 times
freelunch1947
Re: AACS v82 Blu-ray Disc dump submission
Post by freelunch1947 »
Nobody 2 is AACS v82. Someone said it refused to open, but opened on a second attempt. Not for me. Dump:
MKB_v82_Nobody_2_AF7A.tgz
(118.95 KiB) Downloaded 13 times
mediumwave
Post by mediumwave »
The three New Order blu-rays are new keys. Dumps:
MKB_v82_MOVEMENT_8BDE.tgz
(80.14 KiB) Downloaded 9 times
MKB_v82_LOWLIFE_9DDC.tgz
(84.24 KiB) Downloaded 10 times
MKB_v82_BROTHERHOOD_F556.tgz
(95.87 KiB) Downloaded 8 times
You should email those dumps to svq@makemkv.com so a key can be created for MakeMKV's built in hashed key mechanism. A few days after emailing the dump, try the disc again and if a key is available, MakeMKV will download it automatically in the background.
There is a separate second decryption mechanism that MakeMKV supports, the public KeyDB. To contribute to the public KeyDB, use the template and follow the instructions in the first post in the Public KeyDB Disc Submissions thread. Instructions for downloading the keyDB and using with MakeMKV are also in that thread.
