Is my pioneer BDR-XD05s flashable?
Re: Is my pioneer BDR-XD05s flashable?
#226 Post by Coopervid » Mon Dec 08, 2025 3:32 pm
SpaceCity2025 wrote: Mon Dec 08, 2025 2:27 pm I was looking to get some help flashing ny Pioneer BDR-XD05 Drive for UHD discs Drive info is below.
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-XD05
Revision: 3.01
Serial number: OEDL012506UC
Firmware date: 2014-12-26
Drive platform: RS8231
Firmware name: PIONEER BDR-XD05
Firmware version: 3.01/ID34
I appreciate the assistance.
PM is coming.
Take1901
#227 Post by Take1901 » Mon Dec 08, 2025 11:17 pm
Hey there, just recently bought this drive at a great price. Can you PM as well? Cheers mate!
OS device name: /dev/rdisk8
Revision: 3.01
Serial number:
Highest AACS version: 70
#228 Post by Coopervid » Tue Dec 09, 2025 10:07 am
Take1901 wrote: Mon Dec 08, 2025 11:17 pm Hey there, just recently bought this drive at a great price. Can you PM as well? Cheers mate!
Revision: 3.01
Serial number:
PM sent.
Quarter-Tank
#229 Post by Quarter-Tank » Tue Dec 09, 2025 10:09 am
Coopervid wrote: Mon Dec 08, 2025 3:31 pm
Quarter-Tank wrote: Mon Dec 08, 2025 1:00 pm
Coopervid wrote: Sun Dec 07, 2025 5:03 pm
PM sent.
Thanks!! The flash appears to have installed successfully, and the drive recognizes 4K discs now, but it can't seem to decrypt any 4k disc I've tried. Any thoughts?
Thanks again!
MakeMKV v1.18.2 win(x64-release) started
Using LibreDrive mode (v01.0 id=A16AD1CAFF11)
Saved AACS dump file as C:\Users\Paco/.MakeMKV/MKB20_v61_Fifth_Element_7DA5.tgz
log.txt
Debug log started at Mon Dec 08 12:51:52 2025 , written by MakeMKV v1.18.2 win(x64-release)
001005:0000 MakeMKV v1.18.2 win(x64-release) started
DEBUG: Code 3 at R/Ru3B(Mxaw 4&z'5FC}$>4::29395310
SDF v097: PIONEER_BD-RW__BDR-XD06U_1.11_NHDL003109UC
001011:0000 Using LibreDrive mode (v01.0 id=A16AD1CAFF11)
DEBUG: Code 2147483648 at 3}LEXDFfdV,&S#:f:121265499
DEBUG: Code 0 at 3}LEXDFfdV,&S#:f:121268443
Most likely It's not supported yet natively by Makemkv. Read this and install KEXDB.cfg.
viewtopic.php?f=12&t=38293
Amazing - Everything's is working now! Thanks again for your help! Donation sent.
NateWithOCD
#230 Post by NateWithOCD » Tue Dec 09, 2025 11:24 pm
Another drive in search of a 4K flash...thank you for the help!
Revision: 3.10
Serial number:
Firmware date: 2017-06-22
Drive platform: RS8232
Firmware version: 3.10/ID34
Beefgrits
#231 Post by Beefgrits » Wed Dec 10, 2025 4:31 am
Same question. I've had mine for years, label says mfd September 2014. Thanks ahead of time either way.
Revision: 3.00
Serial number:
Firmware date: 2014-07-30
Firmware version: 3.00/ID34
#232 Post by Coopervid » Wed Dec 10, 2025 10:17 am
NateWithOCD wrote: Tue Dec 09, 2025 11:24 pm Another drive in search of a 4K flash...thank you for the help!
Revision: 3.10
Serial number:
PM sent.
sweetrap1
#233 Post by sweetrap1 » Fri Dec 12, 2025 3:49 am
I got the PM, flashed the firmware, and it worked reading and making a backup of a 4k Disk. However, now I am unable to burn discs. Is that expected? Is there a way to go back to the OEM firmware?
#234 Post by MartyMcNuts » Fri Dec 12, 2025 5:52 am
sweetrap1 wrote: Fri Dec 12, 2025 3:49 am I got the PM, flashed the firmware, and it worked reading and making a backup of a 4k Disk. However, now I am unable to burn discs. Is that expected? Is there a way to go back to the OEM firmware?
It should not have any effect on writing discs at all.
sweetrap1
#235 Post by sweetrap1 » Sat Dec 13, 2025 3:31 am
MartyMcNuts wrote: Fri Dec 12, 2025 5:52 am
I have tried 2 different programs to burn a disk and they both fail. One of the programs straight up said this drove isn't compatible. The drive used to work just fine? Any ideas what it could be?
#236 Post by MartyMcNuts » Sat Dec 13, 2025 4:16 am
sweetrap1 wrote: Sat Dec 13, 2025 3:31 am
It is still original Pioneer firmware, albiet a different model but still original firmware. It shouldn't effect disc writing.
I guess you could go back to the original firmware but you would lose UHD readability. Ask whomever helped you flash it.
#237 Post by Coopervid » Sat Dec 13, 2025 12:35 pm
Remove ALL power from the drive. Reboot yor PC. Connect the drive and try again. Report back
ellimist
#238 Post by ellimist » Mon Dec 15, 2025 12:45 am
I was Googling if it was possible to have my external Blu-ray drive could read 4k discs and this forum came up. Here is the information of my drive
Revision: 3.10
Serial number:
Highest AACS version: 82
#239 Post by Coopervid » Mon Dec 15, 2025 9:49 am
ellimist wrote: Mon Dec 15, 2025 12:45 am I was Googling if it was possible to have my external Blu-ray drive could read 4k discs and this forum came up. Here is the information of my drive
Revision: 3.10
Serial number:
PM sent.
gnafuthegreat
#240 Post by gnafuthegreat » Mon Dec 15, 2025 4:37 pm
OS device name: /dev/sr1
Revision: 3.01
Serial number: *snip*
This appears to match what others have had success with, so I'm hopeful! I would like to note I'm on Linux and I'm very comfortable using `sdftool` if it's just a matter of flashing a particular file. I just haven't been able to find that information for this specific drive anywhere. I look forward to any guidance you can provide!
