LibreDrive for Pioneer drives
Rare329
#1786 Post by Rare329 » Sun Dec 07, 2025 3:26 am
Please enable it for this version of the UD04TBD
I also own a newer firmware one and that one's supported btw
#1787 Post by Coopervid » Sun Dec 07, 2025 10:48 am
Rare329 wrote: Sun Dec 07, 2025 3:26 am Please enable it for this version of the UD04TBD
PM sent.
Vicdip
#1788 Post by Vicdip » Sun Dec 07, 2025 9:01 pm
Could you please add this drive to the list
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-TD04
Revision: 1.01
Serial number: LEDL082013WL
Firmware date: 2011-11-04
Highest AACS version: 65
Status: Possible, but very unlikely to happen
Drive platform: Pioneer RS1040
Firmware version: ID78
Disc Information
Label: THE_FORCE_AWAKENS
Timestamp: 2016-02-11 11:03:45
Protection: AACS v50
Data capacity: 39.16 Gb
Disc type: BD-ROM
Number of layers: 2
#1789 Post by Coopervid » Sun Dec 07, 2025 11:05 pm
Not possible. And do not double-post.
infrared
#1790 Post by infrared » Mon Dec 08, 2025 5:15 pm
Is it possible for the BDR-XD07TS w/ Firmware 1.06 to be enabled (and/or UHD flashed)?
OS device name: /dev/sr0
Product: BD-RW BDR-XD07
Revision: 1.06
Serial number:
Firmware date: 2024-10-09
Bus encryption flags: 13
Drive platform: Pioneer RS8D30
Firmware version: GENE
#1791 Post by Coopervid » Mon Dec 08, 2025 7:36 pm
infrared wrote: Mon Dec 08, 2025 5:15 pm Is it possible for the BDR-XD07TS w/ Firmware 1.06 to be enabled (and/or UHD flashed)?
Revision: 1.06
Serial number:
You need to enable Internet access for Makemkv and then restart the drive (power cycle). Only Libredrive. UHD crossflashing is currently not possible.
malcom_ren
#1792 Post by malcom_ren » Tue Dec 09, 2025 12:55 am
Coopervid wrote: Sun Dec 07, 2025 11:05 pm Not possible. And do not double-post.
I’m sorry, I can’t tell who you’re responding to and I am too new to pm.
So is my drive completely useless?
#1793 Post by MartyMcNuts » Tue Dec 09, 2025 2:07 am
malcom_ren wrote: Tue Dec 09, 2025 12:55 am
I believe he was replying to Vicdip
infrared
#1794 Post by infrared » Tue Dec 09, 2025 10:16 am
Coopervid wrote: Mon Dec 08, 2025 7:36 pm
Revision: 1.06
Serial number:
Internet access was already enabled, saw "Downloading latest SDF" in the window, restarted both MakeMKV and the drive (unplugged and plugged it back in) and the drive still says
This is the Windows version of MakeMKV. On Linux, the program hangs if I insert a disc.
EDIT: FWIW I deleted the contents of the .MakeMKV folder, manually downloaded the SDF.bin file and placed it the folder, closed MakeMKV, unplugged the drive, waited 10 seconds, plugged the drive back in, started MakeMKV and it made no difference.
EDIT 2:
Turns out the Linux version has a bug that prevents certain drives from working at the moment.
#1795 Post by Coopervid » Tue Dec 09, 2025 10:23 am
infrared wrote: Tue Dec 09, 2025 10:16 am
Revision: 1.06
Serial number:
I believe it's your firmware version GENE that is not yet supported. Makemkv should have saved a dump of it in the .Makemkv folder. If so please send it to support@makemkv.com.
infrared
#1796 Post by infrared » Tue Dec 09, 2025 10:28 am
Coopervid wrote: Tue Dec 09, 2025 10:23 am
Email sent, thanks anyway for trying to help (and telling me UHD flashing is not possible)
alx89
#1797 Post by alx89 » Tue Dec 09, 2025 10:49 pm
Hi, can my drive be enabled to play UHD disks as well???
OS device name: F:
Product: BD-RW BDR-XS07U
Revision: 1.04
Serial number: CHDL014930UC
Highest AACS version: 82
Drive platform: RS8E21
Firmware version: 1.04/ID05
#1798 Post by Billycar11 » Tue Dec 09, 2025 11:00 pm
alx89 wrote: Tue Dec 09, 2025 10:49 pm Hi, can my drive be enabled to play UHD disks as well???
OS device name: F:
Revision: 1.04
Should already work
alx89
#1799 Post by alx89 » Tue Dec 09, 2025 11:07 pm
I have MakeMKV 1.17.7. Do I need to update it?
#1800 Post by MartyMcNuts » Tue Dec 09, 2025 11:10 pm
alx89 wrote: Tue Dec 09, 2025 11:07 pm I have MakeMKV 1.17.7. Do I need to update it?
No. Just insert a UHD disc and start ripping!
