Combine several mkv files into one
tollie
#1 Post by tollie » Wed Feb 29, 2012 7:47 pm
I ripped a DVD with MakeMKV, now i Havel about 8 mkv files, when I use XBMC it run's only the first file...
How can i make one file out of 8 seperate files..?
Smithcraft
Re: Combine several mkv files into one
#2 Post by Smithcraft » Wed Feb 29, 2012 9:06 pm
They are most likely completely different files(like trailers and ads), but you can use mkvtoolnix to merge the files together.
SC
tollie
#3 Post by tollie » Wed Feb 29, 2012 9:22 pm
They are movie files only, no trailers or ads., I think MakeMKV removed those..
I'am using a Mac, cannot use mkvtoolnix
Smithcraft
#4 Post by Smithcraft » Wed Feb 29, 2012 11:01 pm
Why not?
http://www.bunkus.org/videotools/mkvtoo ... tml#macosx
Have you tired watching the files with VLC to see what all they are? MakeMKV doesn't rip anything below the threshold that is set at 120 seconds(IIRC), or what the user sets. Anything longer and MakeMKV will rip it.
SC
Romansh
#5 Post by Romansh » Wed Feb 29, 2012 11:05 pm
tollie wrote:They are movie files only, no trailers or ads., I think MakeMKV removed those..
Yes you can. Google "mkvtoolnix", go to the download page, and find the "Mac OS X" subsection.
As for XBMC only opening one MKV file - maybe you should ask on the XBMC forum?
