disc played fine but getting errors
eripley
Post by eripley »
I've wiped it clean multiple times, no scratches, no marks. It looks fine. I've tried ripping 3 times in different ways, backup, mkv (all), mkv just the movie itself. It keeps getting errors in the same title file. I feel like lately I've been having a lot of trouble with dvds and blurays, borrowed a ps4 to play them. I watched it before trying to rip it to see if it played ok.
I've started to have a lot of issues with playing disks on the ps4 that didn't happen before, so I don't know if something in the ps4 is contributing, or if I'm doing something while cleaning. There are so many issues with dvds and blurays now that even before playing any dvd or bluray, I wet a microfiber eyeglasses cloth and wipe it down. Then wipe it again with a tshirt. Maybe I wind up cleaning something off that's been coating the disk? Sometimes it seems like the discs are coated with something greasy or oily that I wind up cleaning off.
My old usb bluray player died, it had no issues with bluray. I just bought an external verbatim bluray player that connects via usb so I'm not sure if this is causing issues.
errors:
AV sync issue in stream 3,4,5,6,7 at 0:08:39.296 with duration of 64ms : 2 frame(s) dropped to reduce audio skew to +7.991ms
AV sync issue in stream 3,4,5,6,7 at 0:13:10.528 with duration of 64ms : 2 frame(s) dropped to reduce audio skew to +8ms
AV sync issue in stream 3,4,5,6,7 at 0:16:51.552 with duration of 64ms : 2 frame(s) dropped to reduce audio skew to +8ms
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00377.m2ts' at offset '930834432'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '930834432'
Failed to save title 14 to file C:/Video/backup/makemkv//Spider-Man- Into the Spider-Verse-FPL_MainFeature_t14.mkv
Encountered 53 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
0 titles saved, 1 failed
Re: disc played fine but getting errors
eripley wrote:
Mon Dec 08, 2025 1:45 pm
errors:
You cannot compare playing to ripping. That's like comparing apples and oranges! Players buffer and skip when required and you generally don't even notice. MakeMKV does a 1:1 copy when ripping so must be bit perfect.
Those errors are usually when a drive is having trouble reading a disc.
1. The Verbatims can be a little power hungry so enaure you use ports direct from the motherboard (not case ports). Use USB-C if possible. Otherwise use an AC self-powered USB hub of at least 30w.
2. Give the disc a good cleaning. As you said wiping down didn't help so give it a thorough cleaning using soapy water. Pat dry then let it finish air drying overnight.
You could also try doing an encrypted folder backup. Just uncheck the decrypt box. If this works, you can then open the index.bdmv file in MakeMKV to decrypt the movie. If this doesn't work, you could also open MakeMKV to enable libredrive, then try using ImgBurn to create an encrypted backup.
