Dexter - Original Sin (Blu-Ray) Fails To Rip (Decrypt)
patrick
Post by patrick »
The TV Series "Dexter - Original Sin (Season1)" (Blu-Ray) fails to Decrypt succesfully as it uses a newer version of AACS protection (AACS v82) even using my Asus Libredrive (BW-16D1HT Disk drive) (Un-patched firmware - v3.01)
I let you guys know also by visting your attached link on the Make MKV program.
Make MKV program stated : that the volume key is unknown for this disk - video cant be decrypted. I look foward to the issue to be fully resolved, Thx Guys
Re: Dexter - Original Sin (Blu-Ray) Fails To Rip (Decrypt)
At the moment, MakeMKV does not natively support AACS v82 blu-rays. You should email those dumps to svq@makemkv.com so a key can be created for MakeMKV's built in hashed key mechanism. A few days after emailing the dump, try the disc again and if a key is available, MakeMKV will download it automatically in the background.
There is a separate second decryption mechanism that MakeMKV supports, the public KeyDB. To contribute to the public KeyDB, use the template and follow the instructions in the first post in the Public KeyDB Disc Submissions thread.
patrick
Post by patrick »
OK, Will do, Thankyou for the quick reply.
patrick
Re: Dexter - Original Sin (Blu-Ray) is now Decypted & ripping 🙏
Post by patrick »
Quick update: Dexter - Original Sin appears to be ripping now, 1st disk is ripping as i write this. So thankyou guys
