Re: Pioneer firmware update February 2023
#361 Post by Coopervid » Tue Sep 30, 2025 8:38 am
lezbhonest wrote: Mon Sep 29, 2025 8:09 pm Hi there, posting on here because my driver platform says "Pioneer". Honestly I am really new to this and doing my best to figure it out, but am lost. I tried to SDF tool and it says that the drive platform was MT1959 and wouldn't work. So then I tried the Asus modified tool and that didn't work either. That said "Erorr 1". Please help. Main computer is a mac, but I have an old windows 10 machine that works great.
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Firmware date: 2020-07-21
Firmware version: ID76
PM sent.
mail_stani
#362 Post by mail_stani » Wed Nov 05, 2025 5:56 pm
Hi Coopervid,
Could you sent me the Libre Firmware for my Asus drive too?
Thanks.
OS device name: /dev/sr0
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Highest AACS version: 82
#363 Post by Coopervid » Fri Nov 07, 2025 10:53 am
mail_stani wrote: Wed Nov 05, 2025 5:56 pm Hi Coopervid,
Thanks.
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
PM sent.
haramia
#364 Post by haramia » Fri Nov 28, 2025 10:39 am
Hi Coopervid
Can you please send me the instructions as well? Is it possible to make it region-free and reset the counter?
Manufacturer: PIONEER
Product: BD-RW BDR-212U
Revision: 1.00
Serial number: SFDL001400WL
Firmware date: 2019-01-10
Drive platform: Pioneer RS8F01
Firmware version: ID83
#365 Post by Coopervid » Fri Nov 28, 2025 7:25 pm
haramia wrote: Fri Nov 28, 2025 10:39 am Hi Coopervid
Revision: 1.00
Your drive should already be UHD capable but I will send instructions to update your firmware. Region resetting and region free is not possible but most softwares like Makemkv, AnyDVD and XReveal don't care if a disc is from a different region.
Vicdip
#366 Post by Vicdip » Sun Dec 07, 2025 8:36 pm
Is there a way to update this drive?
OS device name: E:
Product: BD-RW BDR-TD04
Revision: 1.01
Serial number:
Firmware date: 2011-11-04
Highest AACS version: 65
Status: Possible, but very unlikely to happen
Drive platform: Pioneer RS1040
Firmware version: ID78
Disc Information
Label: THE_FORCE_AWAKENS
Timestamp: 2016-02-11 11:03:45
Protection: AACS v50
Data capacity: 39.16 Gb
Disc type: BD-ROM
Number of layers: 2
mlynn
#367 Post by mlynn » Tue Dec 09, 2025 10:58 am
Hi, I've had this a couple of years now, I know this is not a "U" model, but is it capable of ripping 4k discs, and if so, do I need to do anything to enable it? Thanks.
OS device name: H:
Product: BD-RW BDR-212M
Revision: 1.01
Serial number:
Drive platform: RS8F00
Firmware version: 1.01/ID56
#368 Post by Coopervid » Tue Dec 09, 2025 11:29 am
mlynn wrote: Tue Dec 09, 2025 10:58 am Hi, I've had this a couple of years now, I know this is not a "U" model, but is it capable of ripping 4k discs, and if so, do I need to do anything to enable it? Thanks.
OS device name: H:
Revision: 1.01
Serial number:
PM sent.
mlynn
#369 Post by mlynn » Tue Dec 09, 2025 1:29 pm
Thanks, will post back when I get round to trying it.
adam871
#370 Post by adam871 » Thu Jan 22, 2026 3:30 pm
Is there a way to update firmware this drive Pioneer BDR-UD03?
OS device name: F:
Product: BD-RW BDR-UD03
Revision: 1.05
Serial number:
Firmware date: 2015-11-24
Drive platform: RS8510
Firmware version: 1.05
#371 Post by Billycar11 » Thu Jan 22, 2026 3:32 pm
adam871 wrote: Thu Jan 22, 2026 3:30 pm Is there a way to update firmware this drive Pioneer BDR-UD03?
OS device name: F:
Revision: 1.05
Serial number:
Sure just email me that info see below for email
I have a automated flasher for it to make it do UHD
drabb
#372 Post by drabb » Thu Sep 17, 2026 11:44 pm
Coopervid wrote: Fri Nov 28, 2025 7:25 pm
Revision: 1.00
I have the same drive info as above - how do I enable libredrive?
#373 Post by Billycar11 » Thu Sep 17, 2026 11:47 pm
drabb wrote: Thu Sep 17, 2026 11:44 pm
sure email me that info and all others email me no need to post your info here just reach out to me directly
see below for email
#374 Post by Coopervid » Fri Sep 18, 2026 9:21 am
Revision: 1.00
PM sent.
