Can you guys try to fix the incorrect aspect ratio issue?
longernohuman
Post by longernohuman »
Hello everyone,
makemkv is such an awesome software but the aspect ratio issue is reaaly annoying.
I just convert ghost in the shell dvd and it changed the aspect ratio from 1.85:1 to 1.78:1.
and I've seen other people having the same issue with other dvd.
I heard you can fix this with mkvtoolnix but I hope makemkv itself will always choose the correct aspect ratio instead of relying on other software for the fix.
thank you very much for this amazing software.
wmcclain
Re: Can you guys try to fix the incorrect aspect ratio issue?
Post by wmcclain »
DVDs are always either 4/3 = 1.33 or 16/9 = 1.78. Other ratios are made by adding black bars to the sides or top and bottom.
You should see very small black bars at the top and bottom of your title. MakeMKV is just copying what is on the disk.
And there is the additional problem that some DVDs have "split" aspect ratio information - the track is different from the "whole disk" ratio, so... which is right?
longernohuman
Woodstock wrote:
Sun Dec 07, 2025 4:29 pm
In this particular case, why won't we make it ask us to choose between the two?
just like choosing which audio/subs we want.
LoveFilmMuch
Post by LoveFilmMuch »
longernohuman wrote:
Sun Dec 07, 2025 12:56 am
This seems to happen about 0.5% of the time for me, usually first edition/early DVD releases,
the good news, as you already mentioned mkvtoolnix fixes this very quickly (in about 5 seconds in my case).
Honestly pre selecting your ratio may cause you more problems in the long run, I’ve seen some janky DVD configs while backing up my collection, much easier to just check it visually and fix where necessary imo,
good luck!
longernohuman
LoveFilmMuch wrote:
Thu Dec 11, 2025 11:20 am
good luck!
But is fixing it with mkvtool a real and authentic fix? I mean you already export the video from dvd with makemkv and makemkv choosed a specific aspect ratio
wouldn't change it with mkvtool seems more like a fan edit than the acutal aspect ratio of the dvd?
When I've changed it with mkvtoolnix, it just affected the header of the file; the actual encoding stayed as it was on the disk. You can actually have mkvtoolnix recopy the video, but it isn't strictly necessary.
LoveFilmMuch
Yes, the fix (MKVtoolNix) doesn't seem to effect anything bar exactly what you are tweaking, I also use it to fix rare but very annoying audio desync with great success..
On this topic though I did have my first DVD TV series last night where one episode (3 of 6) on the disc came out with the wrong aspect ratio, as to weather it was a disc issue or a 'feature' on the MakeMKV side I have no clue
