StarryEyed
#301
Post
by StarryEyed » Sun Dec 07, 2025 11:51 am
Coopervid wrote: Fri Nov 28, 2025 1:54 pm
StarryEyed wrote: Fri Nov 28, 2025 1:41 pm
My optical drive has recently failed so looking to get a replacement. Before purchasing can I ask a sanity check please: if I get a Verbatim 43890 will I be able to flash this drive myself?
If it's new stock it contains a LG BU40N and you can flash it according to the UHD guide. If it's old stock it might contain a Pioneer UD03 and you have to post again so I will forward a package to flash it.
Many thanks my drive has arrived and I have some spare time to flash it. The drive info is
OS device name: F:
Product: BD-RE BU40N
Revision: 1.05
Serial number: ...
Highest AACS version: 82
So all looks good to me as platform is MT1959. What is the recommended way to flash the above drive I understand I should flash to BU40N 1.03. Do I need the enc option and should I use the makemkv inbuilt flasher as I am ok with using the command line or use the GUI flasher?
I am also keen to get a second internal optical drive are there any internal drives still available that can be flashed?
#302
Post
by Coopervid » Sun Dec 07, 2025 11:56 am
StarryEyed wrote: Sun Dec 07, 2025 11:51 am
OS device name: F:
Revision: 1.05
Serial number: ...
Since you are on Windows, just use SDFTool and the "All you need firmware pack" to flash 1.03.
viewtopic.php?f=16&t=22896&hilit=sdftool+flasher
Drive supply is critical. Also LG stopped now making optical drives. Let me know your country of residence and I will check for an internal drive.
StarryEyed
#303
Post
by StarryEyed » Sun Dec 07, 2025 1:15 pm
Coopervid wrote: Sun Dec 07, 2025 11:56 am
OS device name: F:
Revision: 1.05
Serial number: ...
Flash process worked great. Managed to get the Verbatim flashed drive to work - first time it failed to open the disc. Had to do a system reboot first for MakeMKV to be able to read the drive in Libre format.
I am UK based so having a second internal drive would be very handy, I was shocked when my drive failed I thought that was the end. Glad to get the Verbatim working but also keen to get a replacement internal optical drive if that is possible.
#304
Post
by Coopervid » Sun Dec 07, 2025 4:57 pm
StarryEyed wrote: Sun Dec 07, 2025 1:15 pm
PM sent.
json7
#305
Post
by json7 » Fri Dec 12, 2025 12:35 am
@Coopervid
I purchased the Verbatim 43890 with the following info from MakeMKV and would like to make it compatible with reading UHD discs. Any help would be greatly appreciated! Thanks!
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number:
Firmware date: 2020-06-15
Highest AACS version: 76
Drive platform: RS8511
Firmware version: 1.14
#306
Post
by Coopervid » Fri Dec 12, 2025 12:40 pm
json7 wrote: Fri Dec 12, 2025 12:35 am
@Coopervid
OS device name: E:
Revision: 1.14
Serial number:
PM sent.
TheFlasher
#307
Post
by TheFlasher » Sat Dec 13, 2025 3:36 am
@Coopervid
I have also purchased a Verbatim 43890 it does Blu rays perfectly but was wondering how do I get the PM for the flasher to make it UHD capable?
Revision: 1.14
Serial number: CIDL502547WL
#308
Post
by Coopervid » Sat Dec 13, 2025 8:51 pm
TheFlasher wrote: Sat Dec 13, 2025 3:36 am
@Coopervid
Revision: 1.14
PM sent.
parkthebus
#309
Post
by parkthebus » Sun Dec 14, 2025 5:43 pm
Hi I found this thread searching for drive info. Here is the makemkv info below. Is this workable and can you send a PM if so?
OS device name: E:
Revision: 1.14
Serial number: ------------
saskBee
#310
Post
by saskBee » Sun Dec 14, 2025 7:18 pm
@Coopervid
I have also recently purchased the same drive. Is it possible to get the same flashing kit?
Revision: 1.14
Serial number:
#311
Post
by Coopervid » Mon Dec 15, 2025 9:52 am
parkthebus wrote: Sun Dec 14, 2025 5:43 pm
OS device name: E:
Revision: 1.14
PM sent.
#312
Post
by Coopervid » Mon Dec 15, 2025 9:54 am
saskBee wrote: Sun Dec 14, 2025 7:18 pm
@Coopervid
Revision: 1.14
Serial number:
PM sent.
saskBee
#313
Post
by saskBee » Mon Dec 15, 2025 7:07 pm
Coopervid wrote: Mon Dec 15, 2025 9:54 am
@Coopervid
Revision: 1.14
Serial number:
PM sent.
Thank you, that worked perfectly!
zittrig
#314
Post
by zittrig » Wed Dec 17, 2025 5:36 pm
Little big problem with a 43890 with Pioneer BDR-UD03 .....
Power outage while flashing process .... I was flashing the drive for a friend and I always testing by using all cables. Power cable connection included.
A few seconds after starting the flashing process power is gone. Notebook worked with accu and the Y-Power-Cable was connected also. But without electric power the flashing process was interrupted and the drive now is not usable.
Is it bricked? Or can I rescue it?
#315
Post
by Coopervid » Wed Dec 17, 2025 6:32 pm
zittrig wrote: Wed Dec 17, 2025 5:36 pm
Don't know. It should be most likely in kernel mode. Just run the Flasher and check. Report back.
