Good morning all,
And I hope all is well.
Please be gentle, this is my first post.
Ive just purchased the Brain Ferry Atmos Blu-ray Boys and Girls.
It is failing to rip with the following error message..
"Backing up disc into folder "/Volumes/003_Ripped_Discs/backup/BOYS AND GIRLS"
This disc uses newer version of AACS protection. Please let us know about it by visiting http://www.makemkv.com/a/?TPfdb3s2XE+ITu...
Saved AACS dump file as /Users/Adrian_Jenkins/Library/MakeMKV/MKB_v82_BOYS_AND_GIRLS_00F2.tgz
Backup failed"
Ive clicked on the reporting link, but should I also upload some where the AACS dump file? - just added it to
let me know if I should upload elsewhere?
Adrian
?Blu-ray Audio disc Boys and Girls
- MKB_v82_BOYS_AND_GIRLS_00F2.tgz
- (95.95 KiB) Downloaded 72 times
Re: ?Blu-ray Audio disc Boys and Girls
At the moment, MakeMKV does not natively support AACS v82 blu-rays. You should email those dumps to svq@makemkv.com so a key can be created for MakeMKV's built in hashed key mechanism. A few days after emailing the dump, try the disc again and if a key is available, MakeMKV will download it automatically in the background.
There is a separate second decryption mechanism that MakeMKV supports, the public KeyDB. To contribute to the public KeyDB, use the template and follow the instructions in the first post in the Public KeyDB Disc Submissions thread.
CharlburyF1
This disc is now rippable via updated keydb file.
