Pioneer BDR-212EBK UHD Support?
nco2k
Post by nco2k » Sat Dec 06, 2025 10:52 pm
i would like to add UHD Support to my Pioneer BDR-212EBK, but i have no idea where to find the necessary firmware / tool. can someone please help me out? :D
Manufacturer: PIONEER
Product: BD-RW BDR-212M
Revision: 1.02
Firmware date: 2022-03-09
Drive platform: RS8F00
Firmware version: 1.02/ID56
Re: Pioneer BDR-212EBK UHD Support?
Post by Coopervid » Sun Dec 07, 2025 10:53 am
nco2k wrote: Sat Dec 06, 2025 10:52 pm i would like to add UHD Support to my Pioneer BDR-212EBK, but i have no idea where to find the necessary firmware / tool. can someone please help me out? :D
Revision: 1.02
PM sent.
nco2k
Post by nco2k » Sun Dec 07, 2025 1:34 pm
thanks!
Rabster
Post by Rabster » Sun Jan 04, 2026 9:32 pm
Could you tell me if its possible with this drive also a 212EBK but firmware version is 1.05 and if so could you tell me where to find the firmware / flash instruction Many Thanks
OS device name: I:
Revision: 1.05
Firmware date: 2023-08-01
Highest AACS version: 75
Firmware version: 1.05/ID56
Post by Billycar11 » Sun Jan 04, 2026 10:41 pm
Rabster wrote: Sun Jan 04, 2026 9:32 pm Could you tell me if its possible with this drive also a 212EBK but firmware version is 1.05 and if so could you tell me where to find the firmware / flash instruction Many Thanks
OS device name: I:
Revision: 1.05
There is no way to remote flash that since you updated it
Rabster
Post by Rabster » Sun Jan 04, 2026 10:48 pm
What about downgrading the firmware is that possible
Post by Billycar11 » Sun Jan 04, 2026 11:12 pm
Rabster wrote: Sun Jan 04, 2026 10:48 pm What about downgrading the firmware is that possible
Downgrading is not possible on pioneers
The only way would be to send it into me and I'm not doing send ins until I'm out of drives and even then I will likely only take slim USB pioneers as the desktop ones are to fragile for the mail.
Rabster
Post by Rabster » Fri Jan 09, 2026 7:54 pm
Ok thanks Anyway
TeddyRaspin
Post by TeddyRaspin » Mon Jan 12, 2026 3:39 pm
It is possible of course but it is not of public domain (for obvious reason).
TM2-Megatron
Post by TM2-Megatron » Tue Jan 20, 2026 3:00 am
TeddyRaspin wrote: Mon Jan 12, 2026 3:39 pm
Do we know if it's ever going to be possible to downgrade or crossflash these post-2022 drives to enable them for UHD remotely, eiuther remotely or ourselves?
Since Pioneer drives aren't being manufactured anymore, nobody will be suing... and once all the existing stock has been sold. there'd be nobody left to be "hurt" by releasing whatever tool it is that allows it.
Post by Billycar11 » Tue Jan 20, 2026 3:21 am
TM2-Megatron wrote: Tue Jan 20, 2026 3:00 am
i might start a send in service or if i can make a 1 click program i will release that
