Re: SDFtool Flasher
#1486 Post by Coopervid » Wed Dec 03, 2025 4:05 pm
sukaimakyuri wrote: Wed Dec 03, 2025 1:41 pm Hi, my newly purchased a Verbatim Slimline drive currently cant rip certain DVDs and 4k Blurrays. A few do work, but I mostly use this specifc drives for 4k Blurrays and none of them worked.
Now, first of all, I could not find out if this drive is encrypted, and neither certain if the flashing shown here will work to enable LibreDrive. I downloaded the "All you need firmware pack" and the SDF Tool flasher already. Within the Firmware pack is a LG Slim BU40N, I assume that is the firmware required for this specifc drive. Am I missing something or coud I get started flashing using the flasher with the LG Slim Bu40N Firmware to enable LibreDrive?
Furthermore, from the list of encryped firmware I am uncertain if this drive is in fact coming with an encrypted firmware because I could not find the exact same one in the list but similar enough.
Product: BD-RE BU40N
Revision: 1.05
Serial number: MO4P33E2415
Highest AACS version: 82
Excuse me for the silly questions. I would prefer not to instantly brick my newly purchased drive, given I already own an other drive which is not for 4k Blurrays and just the normal resolution.
As the drive is manufactured in 2024 the firmware is encrypted. SDFTool flasher will set this oprion automatically and you should flash BU40N 1.03 as recommended firmware. If you are using other ripping software besides Makemkv you should flash 1.00. The files are in the "all you need firmware pack" in the SDFTool post by Marty.
viewtopic.php?f=16&t=22896&hilit=sdftool
callumw
Re: SDFtool Flasher
#1487 Post by callumw » Sat Dec 06, 2025 9:12 pm
First time trying this with a UHD drive (my old bluray still works like a champ)
The PC looks like it recognises discs ok, but in MakeMKV it doesn't look right.
It sees the drive as:
OS device name: F:
Manufacturer: 000000
Product: 9999999999999999
Revision: 1.05
Serial number: MOFP7MD4032
Highest AACS version: 81
The drive label says : Hitachi-LG BU40N
Manufactured: July 2025
Firmware Version 1.05
The SDFTool pops up an error when I tried to backup the fimware:
"The drive you have selected does not have the correct drive platform (MT 1959) and cannot be flashed"
Screenshot 2025-12-06 211101.jpg (46.29 KiB) Viewed 12627 times
Would I be right in thinking the problem is the cable I'm got for it?
It's SATA > USB
Drive: https://www.amazon.co.uk/dp/B071CPRK74
Cable: https://www.amazon.co.uk/dp/B073QNN1C5
Re: SDFtool Flasher
#1488 Post by Billycar11 » Sat Dec 06, 2025 10:36 pm
callumw wrote: Sat Dec 06, 2025 9:12 pm First time trying this with a UHD drive (my old bluray still works like a champ)
OS device name: F:
Revision: 1.05
It's SATA > USB
Your case is junk get a recommend adapter from the guide below and a sata to slim sata adapter and it will work
BryanS
Re: SDFtool Flasher
#1489 Post by BryanS » Mon Dec 08, 2025 9:05 pm
I have a BP60NB10 drive that I flashed and it was working great. Drive stated having issues reading discs, so LG said I can send it back to get it replaced since it is under warranty. But in order to do that I need to flash the original firmware back on it. Is that something I can do? If so, how? I was looking at the recover option, but when it comes to selecting the correct new firmware, I didn't know what I would choose.
Any help would be appreciated
Thanks,
Bryan
Bumbles
Re: SDFtool Flasher
#1490 Post by Bumbles » Tue Dec 09, 2025 2:15 pm
All working as hoped. However, if you try to flash the drive while the disk drive tray is ejected SDFTool throws an error with an error number. Would it be possible to check the status of the drive tray and throw a more human readable error if it's currently out?
callumw
Re: SDFtool Flasher
#1491 Post by callumw » Tue Dec 09, 2025 2:32 pm
Returned the drive and replaced it with a Verbatim 43888 ( https://www.amazon.co.uk/dp/B07MTP9VKX )
Much much nicer drive and comes with the cables and adapter options.
Easy firmware backup then install of DE_LG_BU40N_1.03_MK.bin
Currently testing with our Apollo11 UHD disk and it's doing its thing.
Thanks @Billycar11 for the nudge in the right direction
Pre:
OS device name: F:
Revision: 1.05
Serial number: poipoipopoi
Post:
OS device name: F:
Revision: 1.03
Re: SDFtool Flasher
#1492 Post by MartyMcNuts » Tue Dec 09, 2025 10:55 pm
Bumbles wrote: Tue Dec 09, 2025 2:15 pm All working as hoped. However, if you try to flash the drive while the disk drive tray is ejected SDFTool throws an error with an error number. Would it be possible to check the status of the drive tray and throw a more human readable error if it's currently out?
Um, no. It is just a GUI for the sdftool CLI so whatever error it spits out is it.
merlinthesage
Re: SDFtool Flasher
#1493 Post by merlinthesage » Tue Dec 09, 2025 11:58 pm
When I load up SDFtool Flasher 1.3.6
it says my drive isnt a MT1959?
How do I fix this? It should be a 1959 drive
OS device name: J:
Revision: 1.02
Serial number: MO7P5692121
Bus encryption flags: 1F
Harware support: Yes
Firmware support: No
Firmware version: 1.02
is something wrong?
RFAurora
Re: SDFtool Flasher
#1494 Post by RFAurora » Wed Dec 10, 2025 12:51 am
I downloaded the sdftool flasher for my PC to try and use it for my Blu-Ray player, but when I open the tool, the box opens like this and I can't resize it to use it I have a Windows 11 PC.
sdftool weird size.png (22.05 KiB) Viewed 12253 times
blind-s33r
Re: SDFtool Flasher
#1495 Post by blind-s33r » Wed Dec 10, 2025 1:11 am
RFAurora wrote: Wed Dec 10, 2025 12:51 am I downloaded the sdftool flasher for my PC to try and use it for my Blu-Ray player, but when I open the tool, the box opens like this and I can't resize it to use it I have a Windows 11 PC.
Cough
NOTE: If the GUI looks a bit deformed (happens on a 4k monitor), you can right click the exe and select properties. In the compatibility tab, click "Change high DPI settings" then under "High DPI scaling override" tick the box and select "System (Enhanced)" in the dropbox.
Cough
RFAurora
Re: SDFtool Flasher
#1496 Post by RFAurora » Wed Dec 10, 2025 1:42 am
blind-s33r wrote: Wed Dec 10, 2025 1:11 am
Cough
Cough
Thank you.
McMurphy66
Re: SDFtool Flasher
#1497 Post by McMurphy66 » Thu Dec 11, 2025 4:43 pm
Thank you Marty, I finally received my UHD blu rays from storage and the Buffalo flashed drive works a treat - faster than expected. I really do appreciate all the work you do! Be lucky. :D
McMurphy66 wrote: Wed Dec 03, 2025 12:47 pm
MartyMcNuts wrote: Wed Dec 03, 2025 7:10 am [quote=McMurphy66 post_id=189135 time=<a href="tel:1764735582">1764735582</a> user_id=104006]
Apologies if this is in the wrong thread…newbie post but not new to the amazing makemkv software.
Bought the Buffalo BRUHD-PU3-BK. Read through the threads and wasn’t sure if it was BUN-40 flash process. I’m confused what to use, not done this before.
Thanks all.
OS device name: E:
Manufacturer: BUFFALO
Product: Optical Drive
Revision: BN14
Serial number:
Firmware date: 2121-06-21 13:33
Highest AACS version: 48
Yes, it's a BU40N. You can flash it to BU40N 1.03-MK.
Thank you Marty, I really appreciate your reply.
I’ll use the LG BU40N 1.03mk. Is it simply ‘select drive’ “select write’ open this firmware from the pack and start?
[/quote]
Re: SDFtool Flasher
#1498 Post by MartyMcNuts » Thu Dec 11, 2025 10:50 pm
McMurphy66 wrote: Thu Dec 11, 2025 4:43 pm Thank you Marty, I finally received my UHD blu rays from storage and the Buffalo flashed drive works a treat - faster than expected. I really do appreciate all the work you do! Be lucky. :D
Thanks all.
OS device name: E:
Revision: BN14
Serial number:
[/quote]
Yep.
ArifHubble23
Re: SDFtool Flasher
#1499 Post by ArifHubble23 » Fri Dec 12, 2025 2:56 pm
Please don't shoot me! I am rather computer illiterate! Apologies to anyone who has a migraine from the questions I am about to ask.
New drive: Verbatim 43890 USB 3.2
Issue: not reading UHD 4K discs but can see the disc title on PC- Make MKV 'hash error' occurs
Make MKV drive log:
Revision: 1.05
Serial number: MO1P6AE5410
Highest AACS version: 77
If someone could advise on what firmware to flash to this drive to enable UHD compatibility I would be grateful. Much thanks.
Mr_Orange
Re: SDFtool Flasher
#1500 Post by Mr_Orange » Fri Dec 12, 2025 10:43 pm
ArifHubble23 wrote: Fri Dec 12, 2025 2:56 pm Please don't shoot me! I am rather computer illiterate! Apologies to anyone who has a migraine from the questions I am about to ask.
Make MKV drive log:
Revision: 1.05
Flash BU40N 1.03MK.
