remove RegionLock permanentely?
kapqa
Post by kapqa »
Hello ,
i have received Bluray UHD drive, and it functions well,
very happy with it;
now however would like to play DVD, and it seems it is from another "region".
The program alerts me
You can only change the drive region code 5 more times
Is there a way to make this drive a bit more "universal"?
A bit like with the Standalone-DVD-Bluray drives (requiring possibly "hack")?
Thank you very much.
https://ibb.co/j9qWP9g2
Re: remove RegionLock permanentely?
kapqa wrote:
Thu Dec 04, 2025 8:24 pm
Hello ,
very happy with it;
No there is not. MakeMKV doesn't care about region coding anyway. You didn't say what player you are using so I assume you are using VLC. Just associate VLC with MakeMKV and ensure it is running when you go to play the disc.
Although, direct disc playback isn't recommended. It will wear out the drive and possibly the disc quite a bit faster. Much better to rip the disc once (saving the drive and disc) and play the resulting mkv file as many times as you want.
Ezatoka
Post by Ezatoka »
In the old days there were RPC1 firmwares for DVD drives, which made the drive region free. But ever since the BluRay/DVD combos, I never heard of any current firmware doing so.
Mark_McG
Post by Mark_McG »
Hello ,
very happy with it;
As it's a DVD Makemkv will backup the disc to a decrypted .iso file directly. You can mount the .iso as a disc in windows by right clicking the .iso and selecting mount. Then play it as normal.
kaysee
Post by kaysee »
Backing up a DVD using an old blu-ray drive yielded this message in MakeMKV:
"Drive BD-ROM ********* has RPC protection that can not be bypassed. Change drive region or update drive firmware from http://tdb.rpc1.org. Errors likely to follow."
